jesse wall
Posted: Fri Apr 25, 2003 1:06 pm Post subject: are camber boxes legal ? |
Are rear camber boxes legal in scca or pca or 944 cup ? thanks Jesse _________________ jesse wall 'new driver' , 87 924s |
Posted: Fri Apr 25, 2003 10:26 pm Post subject: |
What exactly do you mean by a rear camber box? _________________ Vaughan Scott
John Brown
Posted: Fri Apr 25, 2003 11:42 pm Post subject: |
Ask Dave about the cup. But I don't think they would be. If they are not OK for SCCA then you can not enter as an ITS car; and if they are not legal for PCA then you can not enter as an PCA H or I car. So, no.
John |
jjadczak
Joined: 03 Jan 2003 Posts: 346 Location: Accokeek, MD
Posted: Tue Apr 29, 2003 4:49 am Post subject: |
Ditto's, what are you talking about? |
jesse wall
Posted: Tue Apr 29, 2003 12:31 pm Post subject: camber box |
Where the rear control arm fits into the torsion tube a metal box is placed that allows the camber to be changed by tightening bolt after shims are added , this lets you adjust camber without affecting toe and allows more camber,folks sell them for 911 and 930 looks easy enough to weld one up , I think if you were to slot the holes in the torsion carier making inside hole lower and outside [towards wheel] hole higher you could get more camber , the box allows easy adjustment just crawl under car and have buddy tell you when you have enough camber by adding shims . Found this in fixing der porsche ,guys were getting 931 track ready , wanted to know if anyone has had esperiencebuilding one and if it would be legal , think it would be for pca improved anyway may be too much trouble Jesse _________________ jesse wall 'new driver' , 87 924s |
Posted: Tue Apr 29, 2003 9:45 pm Post subject: |
One more thing, this might aggravate any attempts to install spherical bearings into the rear trailing arms, at least using the commercially available kits. _________________ Vaughan Scott
