UPDATE TO WIRING HARNESS
924ttrouble
PostPosted: Fri Mar 14, 2003 11:55 am    Post subject: UPDATE TO WIRING HARNESS Reply with quote
Update to wiring harness, I'm still in the process of rewiring the harness. so far I traced a red/green wire all the way through the harness that melted 4 wire together. The wire went from the headlight motor through the main harness to the light switch and melted the switch, from the switch to who knows what right now I'm still peeling back wire. I'm splicing in a new switch as I go. I'm taking my time with this project, this is going to a very long and slow process to get this right. Only problem that I ran into so far is a connector in the main harness that has one side melted and I'm having a hard time tracing back that wire.
PostPosted: Fri Mar 14, 2003 2:38 pm    Post subject: Reply with quote
way to go! When you finish you'll get a special mention in the 924 electrical hall of fame.
924ttrouble
PostPosted: Fri Mar 14, 2003 3:02 pm    Post subject: Reply with quote
Thanks, I'm going to give it my ultimte attention, and hopefully everything is going to work.
CMXXXI
PostPosted: Sat Mar 22, 2003 10:35 pm    Post subject: Reply with quote
Careful.....
BZZZZZZZZZZZZZZZZZZZZZTTT !!!
'79 Eurospec 931
Neil924
PostPosted: Sun Mar 23, 2003 3:18 am    Post subject: Reply with quote
BZZZZZZZZZZZZZZZZZZZZZTTT !!!?
Don't you mean
BZZZZZZZZZZZZZZZZZZZZZTTT !!!, Aaaaaahhhhhhhhhhhh!!!, Mommy!
924ttrouble
PostPosted: Wed Mar 26, 2003 12:05 am    Post subject: Reply with quote
The wiring harness is done and it didn't go BZZZZZZZZZZTT
everything is working so far, that I can tell and more important the car started. New problem came up loud banging noise in the engine.
PostPosted: Wed Mar 26, 2003 1:57 am    Post subject: Reply with quote
horror movie tonight: Valves and piston colide
3 928s,
