DELETING:posts ya dont like,did i say that ..
Post new topic   Reply to topic    924Board.org Forum Index -> About The Board
Joes924
PostPosted: Sat Aug 04, 2001 3:07 am    Post subject: Reply with quote
Let me guess theres no way for the poster
to delete a message they dont like .. / ??/ Theres a couple i want gone in less than 60 seconds so.. Is there a way is the technology there... can it be done / Joe D.
PostPosted: Sat Aug 04, 2001 10:34 am    Post subject: Reply with quote
Joe,
what you do is go display the post then click the "edit" icon under your post.
If there are no replies to the post then a little "Delete this post" tick box appears at the top of the Options. Click the delete box and hit submit.
If there are replies to the post you can't delete it. In this case your only option is to edit the post and remove or correct whatever it was that made you want to delete it.
Hope that helps.
Joes924
PostPosted: Tue Nov 20, 2001 2:40 am    Post subject: Reply with quote
Thanks Syd.
Post new topic   Reply to topic    924Board.org Forum Index -> About The Board All times are GMT + 10 Hours
