GTS Rules now up
Post new topic   Reply to topic    924Board.org Forum Index -> Rules and Regs
PostPosted: Wed Mar 05, 2003 1:09 pm    Post subject: GTS Rules now up Reply with quote
It's official, they're up:
http://www.924.org/GTSChallenge/rules.htm
Remember, this will be a preliminary season, to gather data, so we can reassess weights and competitiveness for 2004 when we run a full points season.
vehdyn
PostPosted: Tue Mar 11, 2003 11:28 am    Post subject: Reply with quote
What are the IT rules relative to tire/wheel size. Stock diameter? What about width? Thanks.
Ken
95 M3
bmw22
PostPosted: Wed Mar 12, 2003 6:15 am    Post subject: IT wheel specs Reply with quote
ITS, ITA stock diameter, 7" width max
ITB, ITC stock diameter, 6" width max
12" diameter can upgrade to 13"
Mark Barr
325is GTS2 #22
mailto:markbarr@wpa.net
PostPosted: Wed Mar 12, 2003 9:11 am    Post subject: Reply with quote
OK, but wasn't there some silliness about allowing the BMW's to run 16" rims in ITS?
bmw22
PostPosted: Wed Mar 12, 2003 9:20 am    Post subject: Reply with quote
Actually, I think it was the 944 cars
Mark Barr
325is GTS2 #22
vehdyn
PostPosted: Wed Mar 12, 2003 9:52 am    Post subject: Reply with quote
But what about the cars that currently dont fit into ITS but are running basically at IT rules. Ala the M3's, 944 turbos etc. I am assuming stock diameter and any width? BMW prepared says whatever tire fits inside wheel wells. Stock class allows an inch wider and I think PCA stock allows the same. Any info would be appreciated as I am buying new rims. Thanks.
Ken
95 M3
bmw22
PostPosted: Wed Mar 12, 2003 10:11 am    Post subject: Reply with quote
Under current rules, if you are to BMWCCA Prepared specs, then you are within GTS specs. Eventually we want to get to the point where GTS has it's own set of modification rules, that would still allow cars to run as PCA Prepared or BMWCCA Prepared. If you want to get wheels that BMWCCA Prepared allows, you will be safe as far as GTS future rules are concerned. Any rules added or changed will be to enhance the cars performance not to decrease performance.
Mark Barr
325is GTS2 #22
vehdyn
PostPosted: Fri May 16, 2003 4:58 am    Post subject: Reply with quote
Vaughan,
I have a question about dampers. Remote Reservoir dampers are not allowed in IT right? Are they allowed in the PCA classes that will run in GTS? I am not as familiar with PCA rules. Any feeling on whether they will be allowed in 2004? Thanks.
Ken
95 M3
bmw22
PostPosted: Fri May 16, 2003 5:08 am    Post subject: Reply with quote
RR shocks are allowed in BMWCCA Prepared cars and I'm not sure about PCA. Here is what the PCA says about shocks:
"Shock absorbers are free providing they are of same type, using the same pick-up points, as supplied by the factory."
If you ask 3 people to interpret that you would get three different interpretations.
I would say the RR shocks are fine if the use the factory pick-up points.
I would have to talk to a PCA official to get the Clubs intent of this rule.
Mark Barr
325is GTS2 #22
PostPosted: Fri May 16, 2003 5:24 am    Post subject: Reply with quote
RR shocks are regularly allowed in PCA Stock classes, in addition to the rules appearing to allow them. RR shocks were legal in IT until this year, when they were made illegal (actually, it was a good year ago, but not made effective until this year). Supposedly this was to reduce cost.
vehdyn
PostPosted: Fri May 16, 2003 7:03 am    Post subject: Reply with quote
I guess it reduces costs if you dont already have them. Thanks for the info.
Ken
95 M3
Post new topic   Reply to topic    924Board.org Forum Index -> Rules and Regs All times are GMT + 11 Hours
