DOUG
Posted: Sun Feb 02, 2003 11:50 am Post subject: limited slip differential for v8 931 |
I HAVE A 1982 931 WITH SB CHEVY MOTOR CARBERATED. I BOUGHT THE CAR IN NEW YORK FOR $1600 dollars. IT HAD A TIRED 350, SO MY MECHANIC IS IN THE PROCESS OF REPLACING IT WITH A REBUILT 350 WITH 0 MILES ALL STOCK. I PAID 650$ for the new motor , which is a 4bolt main out of a 86 truck and i'M UNSURE OF THE HORSE POWER. MY PROBLEM IS , I'TS NOT POSI ! OR LIMITED SLIP ! IS THERE A UNIT I CAN REPLACE IT WITH???? |
CBass
Posted: Thu Feb 06, 2003 4:07 am Post subject: |
The 1982 931 used a transmission which is nearly identical to the 944 tranny, so any differential that would fit a 944 will fit your tranny.
I looked up the differential on www.quaifeamerica.com, and they only listed them for 1986 and up 944s, although I'm not sure what the difference in transmission is.
You would probably be better off to find a 944 or 968 transmission that already has a LSD, it wouldn't cost a great deal more, and you could be sure it would work.
If you look under suspension on the left bar at www.944S2.com, you'll find some info there. |
turbobob9242
Joined: 08 Feb 2003 Posts: 138 Location: Hinckely Ohio
Posted: Thu Aug 21, 2003 8:10 am Post subject: Phantom Grip LSD |
I here the phantom grip LSD is a decent unit and much cheaper!!
Supposed to handle 500HP. _________________ Bob Ward
80 9214 turbo, w 5.3 LS V8 |
CBass
Posted: Wed Sep 10, 2003 1:57 pm Post subject: |
There are also horror stories of it destroying expensive transaxles... I can't verify any of these.
I think it's better to spend the extra dollar, and get a good differential, like a Quaife, or a Guard Transmission... Tom Pultz has a GT diff, and he has said nothing bad of it that I've heard. They're quite a bit cheaper than a Quaife unit. _________________ '81 931 in various states of assembly |
keith
Joined: 21 Sep 2003 Posts: 24 Location: Charlotte, NC
Posted: Fri Oct 10, 2003 12:36 pm Post subject: |
Phantom Grip will not even handle 300 flywheel HP. _________________ keith
86/9 951
the RUNT. |
N2924s
Posted: Sun Nov 02, 2003 4:44 am Post subject: |
I would recommend getting a 944 Turbo transaxle, whether with or without the LSD, LSD being preferred obviously. Anything less in the 924/944 series of trannies will not be able to handle the SBC's output. This is based on an acquaintance's experiments with a SBC in his own project car.
The average opinion on the Phantom Grip is that it's junk, mediocre at best.
YMMV Al |
beario
Joined: 03 Nov 2002 Posts: 139 Location: st albans/cornwall
Posted: Fri Dec 12, 2003 11:22 pm Post subject: |
944 turbo transaxle is well up to the job as its what i have in my 924s rover/bick 215 powered car... _________________ theres no replacment for displacement....V8 |
