turbo gaskets
PostPosted: Mon May 28, 2001 10:31 am    Post subject: Reply with quote
Email: s2003r@yahoo.com
Date: 28 May 2001
Time: 09:31:41
i need some help in finding the gaskets needed to put the turbo and exhaust back on my 82 931. the only two places where i can find them are auto atlanta and the dealer and both of them want about 50 dollars just for one gasket. those prices makes it tempting to just risk using the old ones again. thanks for any help you may be able to give.
PostPosted: Mon May 28, 2001 2:43 pm    Post subject: Reply with quote
Email: bcookt06394@yahoo.com
Date: 28 May 2001
Time: 13:43:33
What part #? What part? I got mine from the dealer, but I don't think it was $50USD.
bc
PostPosted: Mon May 28, 2001 11:47 pm    Post subject: Reply with quote
Email: Porschetech@mac.com
Date: 28 May 2001
Time: 22:47:16
give me the part numbers and I can check with my supplier
PostPosted: Tue Jun 19, 2001 1:07 am    Post subject: Reply with quote
Email: TroyDest@aol.com
Date: 19 Jun 2001
Time: 00:07:08
Sean, Make sure you are buying the gaskets that you actually need for your turbo. There were changes made in gaskets and seals through the years. I also have an '82 931 and replaced all the seals and gaskets when I first got it because of leaks. I spent about $200 (yes, one of them was $50) at my local dealer only to find out later that I didn't need some of the gaskets for my model turbo. However, it did seal up just fine. Good luck.
PostPosted: Fri Jul 27, 2001 6:33 am    Post subject: Reply with quote
Email: rog924@aol.com
Date: 27 Jul 2001
Time: 05:33:26
Call PAPI just replaced my turbo and the gaskets were much cheaper they like part numbers so if you can get them first it will help 1 800 944 2964
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    924Board.org Forum Index -> Posts Rescued From the Old Board All times are GMT + 11 Hours
