nd4spd924S
Joined: 05 Nov 2002 Posts: 14 Location: chester springs pa
Posted: Tue Nov 05, 2002 4:47 pm Post subject: Need trans for my '87 924S will 944s2 trans work in my car |
i have a '87 924s with broken trans . ring and pinion busted
there is a brand new 944 s2 trans on ebay right now will this fit in my car? |
beario
Joined: 03 Nov 2002 Posts: 139 Location: st albans/cornwall
Posted: Wed Nov 06, 2002 4:10 am Post subject: Re: Need trans for my '87 924S will 944s2 trans work in my c |
nd4spd924S wrote: | i have a '87 924s with broken trans . ring and pinion busted
there is a brand new 944 s2 trans on ebay right now will this fit in my car? | should fit straight in as freind has 944 turbo box bolted in his 924 carrera gt....i dont think he had to modify to get in.......... |
Posted: Wed Nov 06, 2002 4:37 am Post subject: |
this should work although your friend with the CGT probably had to replace the torque tube as well as the CGT has a G31 which bolts up alot differently than a 944 tranny _________________ 3 928s, |
gohim
Posted: Wed Nov 06, 2002 6:44 am Post subject: |
It should bolt right up...
But, you will need to find a way to plug the speedo drive hole in the transmission since the 924S takes the speedo drive from the left front spindle.
The gear ratios will also be different, so I would expect your car's performance specs to be altered. |
