Wiring question
Nick Neves
PostPosted: Sun Nov 03, 2002 8:06 am    Post subject: Wiring question Reply with quote
I've got a tuffy here, guys. I need a description of what each wire goes to in the two nine pin connectors that hook the engine up to the main loom in an 81' 931. These two nine pin connectors are located on the firewall in the back of the engine compartment. Not all nine pins are used in each connector. I'm putting a 944 motor in the thing and my 931 manual has a very worn out wiring diagram that is so faded I can't read the colors or make out half of the paths. If there is a sight with all this info already, please direct me to it, or if you know the answer and could help me out, my e-mail is sevenup@rocketmail.com
thanks a ton... Nick Neves><>
924 turbo
PostPosted: Sun Nov 03, 2002 3:50 pm    Post subject: Reply with quote
I'll get this information for you after I get get home from work.
Jon Furst
