Ignition Timing Map
Raize
PostPosted: Sun Apr 14, 2024 3:09 am    Post subject: Ignition Timing Map Reply with quote
Anyone have any comments on whether this would be a good ignition timing map for a N/A 2.0 with boost? Assume AFRs are done properly, Euro compression ratio, and intercooling.
PostPosted: Sun Apr 14, 2024 4:45 am    Post subject: Reply with quote
What fuel?
Raize
PostPosted: Sun Apr 14, 2024 5:06 am    Post subject: Reply with quote
Cedric wrote:
What fuel?
UK 99 RON which would be equivalent to USA 95
PostPosted: Sun Apr 14, 2024 9:38 pm    Post subject: Reply with quote
US-spec 931, but here's my ignition map (from the Megasquirts experts thread):
I'm not sure why you would want such high advance of 52 on high vacuum/rpms?
The low RPM values around 6-8 degrees control the idle speed, with the very high advance at 600rpm to keep the car from stalling.
I have actually massaged things a bit since the above was posted, but this should give a decent baseline... there were a few discontinuities that needed to be sorted, mainly I think it was the progression from the 45 to the 80kPa line, and from 1500-2000rpm - that was a bit of an abrupt jump, so driveability around 2000rpm and light throttle in stop-and-go traffic got pretty jumpy and unpleasant.
PostPosted: Sun Apr 14, 2024 9:52 pm    Post subject: Reply with quote
Update - posted my latest maps, so linking from the Rennlist thread... tuned for US 93 octane gas (though far from the limit, I have a WBO2 sensor but no knock sensor and haven't run on a dyno, just street tuning).
Boost is set at 14psi...
You can see the difference in the ignition map for smoothing vs. the previous one. Much happier and smoother in stop-and-go traffic at 2000rpm.
Raize
PostPosted: Sat Apr 20, 2024 9:53 pm    Post subject: Reply with quote
Thanks for the data.
Couple questions:
1. You have all your timing in at 2500 RPM from 85 KPa upwards. I was going with the stock Porsche ignition curve being all-in at 3000-4000rpm, are they too conservative?
2. What's the purpose of the retarded timing below 3500 RPM at high vacuum (55 KPa and upwards)? I understand the 6 and 8 part is for idle control, is the 16-25-30 just smoothing?
3. Is it generally knock-limited or MBT-limited with the gas you run?
PostPosted: Sun Apr 21, 2024 9:24 am    Post subject: Reply with quote
Couple questions:
I'd say so. But I'm tuned for much better octane too. Plus we have better controls, more precise, more complex and reliable, etc.
Exactly.
I'm not knock limited or anything of the sort; this is a conservative tune that doesn't run to the limit, since I haven't dynoed or run any knock detection.
Raize
PostPosted: Sun Apr 21, 2024 7:48 pm    Post subject: Reply with quote
That's good to know. The only data I have for my car is that on 99 octane (USA 93) it starts to lightly knock at 36 degrees timing and on 97 octane (USA 91) it starts to lightly knock around 32 degrees timing, at 120 KPa.
The NA obviously has higher compression than the 931 so would need less timing because of that. But equally, it has a worse combustion chamber shape that requires more timing than the 931.
Also not sure if there's a pressure level where the engine will just knock because of the high-ish 9.3:1 compression ratio and no amount of ignition timing retard will change it, and what that pressure would be for an intercooled NA running premium gas.
PostPosted: Mon Apr 22, 2024 9:11 pm    Post subject: Reply with quote
I'm surprised that your motor will knock that easily. Doesn't seem right, perhaps it wants some clean-up in the combustion chambers?
We also have an NA racecar, with a basically stock NA head on it, used to run 9.5:1 compression with stock cam, 93 US octane, and no problem running up to 42 degrees of compression (max power) as long as the fueling's good.
So on that latter point, how is your fueling, do you have a wideband?
PostPosted: Mon Apr 22, 2024 11:38 pm    Post subject: Reply with quote
What Vaughan said above. I had the same thing (9.5:1 with 93 Octane) at 41 degrees and ran a CO of 12.6-13.1 with no knock. Now we both have 11:1 compression engines (I'm running 100 Octane) and a bit less advance with no knock.
1979 924 NA race car
1982 924 Turbo almost a PoS
Raize
PostPosted: Tue Apr 23, 2024 5:50 am    Post subject: Reply with quote
I have 14-14.5 AFR so it's not ideal.
Will be reducing this to around 12 soon. Should be able to pick up some more timing with that change.
PostPosted: Tue Apr 23, 2024 7:13 am    Post subject: Reply with quote
12 is too rich unless its turbocharged...
PostPosted: Tue Apr 23, 2024 5:20 pm    Post subject: Reply with quote
12,7 at n/a for max power and then lower as boost goes up,how much depending if you use a supercharger or turbocharger.
One thing here, never use any ones ignition map other than for reference to build a rough map, things can be a bit different between setups for a multitude of reasons, start a bit conservative and work yourself up.
Raize
PostPosted: Sat Apr 27, 2024 9:39 pm    Post subject: Reply with quote
I don't have that fine control over the fuelling, with K-jetronic I can basically have two settings with my vacuum-diaphgram WUR - one for vacuum and one for positive pressure.
In theory you could make it get richer gradually as boost increases by using stronger springs in the WUR. I'm using a supercharger so I'm not really in a "partial boost" situation often like with a turbo needing to spool up.
Raize
PostPosted: Sat Apr 27, 2024 11:08 pm    Post subject: Reply with quote
Just did my K-Jetronic Quantity Testing on the new Volvo metering head and I have the normal slight variances...
3% at maximum flow
6% at half way up
6% near idle
Cylinder 4 is the hot one on these engines right? I will put my highest flowing injector to it if I can.
