Judge
Posted: Tue Apr 02, 2024 10:30 pm Post subject: Porsche 924 won't start |
Hello there, I bought a Porsche 924 from 1979 to fix it. Right now it is sleeping outside, and I'd like to get it running enough so that I can park it in my driveway.
The previous owner tried fixing it but couldn't get it running on its own, but it did run with an external fuel pump.
He did the injectors, hoses, thermostat, fuel filter, cooling pipe, and the ignition coil.
He replaced the fuel pump relay, but still, despite the engine cranking, the fuel pump would not start.
I replaced the fuses, and as a temporary solution, I've decided to run a wire with an amp from the battery to the fuel pump. I can hear the fuel pump turn on, and I tried cranking the engine but it wouldn't start.
I tried again, but before I could get inside and put the ignition on, the engine made a screeching sound, see this video:
https://imgur.com/a/6zxL6N6
From what I could guess, it seems the K-Jetronic has got air in the system, or it is flooding the engine.
I just wanna start the car and get it inside my garage, any ideas?
Additionally I'm in the South of France, apparently there are other French owners on the forum. |
Beartooth
Posted: Wed Apr 03, 2024 3:44 am Post subject: |
When I was getting my car going, I used a jumper wire in place of the relay until I was able to get a good relay. The two terminals that need to be connected are the one that's 90 degrees off from all the others, and the one opposite it. That screeching sound could be the the injectors, they make that kind of noise when they're flowing fuel. If it's making that noise as soon as fuel pressure is applied, than there's probably something wrong or badly misadjusted in the fuel injection.
I'd take the fuel distributor off (the square piece the injector lines connect to) and make sure the plunger moves freely. Be careful when you take it out: if it's not bound up, it can drop out, and it's a very finely machined piece that you don't want to damage. A fuel pressure gauge is something you'll probably need sooner or later; you'll want to check supply pressure, and then something called control pressure, which is another circuit to allow the system to supply more fuel for warm-up.
One other thing, there's a basic setting for the fuel distributor that may be out. Next to the fuel distributor is a hole with a stopper in it, and if you remove that, there's an allen screw. That fine-tunes the position of the arm that goes from the air flow plate to the fuel distributor; as airflow increases, the plate pushes the plunger on the fuel distributor, increasing fuel flow. Similarly, turning the screw clockwise increases fuel flow. It could be somebody turned that screw too far in, and that would cause fuel to flow even with the air flow plate at rest. Make sure the plunger and air flow plate and arm are free first, but if they are, then you might need to reset the adjustment. It's been a while, but I seem to remember what worked best was to back it out quite a bit, then (with the fuel pump running - and you shouldn't be hearing any screeching) turn it back clockwise to the point where you get that sound as soon as you move the plate, but no change in sound with the plate at rest. One last note on that screw: if you back it out too far, it'll come out. It's not the end of the world, but you'll probably have to take things apart to get to where you can thread it back in.
Before you dig too far into the fuel injection, you'll want to make sure you've got spark. I wouldn't monkey with the timing for now, but if you get stumped and think that may be off, there are ways to set that without the engine running or a timing light. Anyway, apologies if I'm talking below your level - I just want to make sure the bases are covered. It sounds to me like something badly out of whack with the fuel injection, and you never know what the previous owner might have monkeyed with. They're also very sensitive to contamination: I flushed all my fuel lines and circulated fuel through the system, but still chased gremlins for a while until all the varnish and gunk worked its way out. _________________ 1980 931 diamond in the rough |
Judge
Posted: Wed Apr 03, 2024 4:57 am Post subject: |
Thanks a lot that's very insightful.
It's actually my first project car so, lots of things in pratice that are different from theory
Some other guy suggested that the problems could all come down to a faulty ignition and bad grounds. I'll be checking those tomorrow, and I'll update.
Because obviously there's fuel, air, and probably compression, I might be missing sparks in the engine |
copeina
Joined: 06 Dec 2023 Posts: 7 Location: Calgary, AB, Canada
Posted: Wed Apr 03, 2024 6:11 am Post subject: |
x2 for the great description Beartooth. I'm in a similar spot and also in the process of learning about the CIS system. Much appreciated!
/Kris _________________ 1978 924 |
Judge
Posted: Wed Apr 03, 2024 9:46 pm Post subject: |
[url]Good news! I have fuel pressure! Bad news, I have a fuel leak.[/url]
Well that's a new clue as to why it won't work. |
Judge
Posted: Fri Apr 05, 2024 1:36 am Post subject: |
I manage to fix the fuel leak and now the K-Jetronic injection makes a noise again, meaning it has fuel running it in, the question now is whether the fuel in it goes in the engine or now. Because if it does, then I have no spark. Any ideas of where I should check next? |
Posted: Fri Apr 05, 2024 3:16 am Post subject: |
Well, it's easier to pull a spark plug wire and see if you have spark there, than to pull a fuel injector and look at that. So definitely check spark first. _________________ Vaughan Scott
Judge
Posted: Fri Apr 05, 2024 3:22 am Post subject: |
That's actually pretty smart. Do I need to pull the spark plug too or can I see anything with the spark plug wire? |
Joined: 28 Feb 2008 Posts: 1361 Location: Washington DC area
Posted: Fri Apr 05, 2024 4:19 am Post subject: |
Pull the wire and stick in a spare spark plug. Have someone crank the engine while you ground the body of the spark plug (just touch it against a metal part of the engine). If you see a spark at the tip of the plug you are half way there! _________________ 1979 924 NA race car
1982 924 Turbo almost a PoS
Judge
Posted: Sat Apr 06, 2024 8:32 pm Post subject: |
Update:
I've send staring fluid down the intake manifold while a friend cranked the engine, and nothing.
This leads me to believe that the engine has no sparks.
Time to double check the whole ignition system. Actually pretty happy about that because I don't have to rebuild a 1970 injection system. |
Posted: Sat Apr 06, 2024 9:37 pm Post subject: |
Yup, that's a quick easy answer there. Start at the coil, verify you have power there (should be 6V with ignition on, 12 while cranking), then go through the wiring for the pickup lead from the distributor to the ignition box, those often get flaky.
Don't count on the fuel system being fine just yet, though; at very least the injectors ought to be replaced, and the warm-up regulator is unlikely to be happy. Just hoping the fuel distributor is OK. _________________ Vaughan Scott
Raize
Posted: Sun Apr 14, 2024 3:31 am Post subject: |
That screeching sound is K-jetronic flooding your engine.
It's a very distinctive noise.
Your engine will NEVER start under this condition and you will need to change your oil once you get the engine running as it will be heavily fuel contamined.
A leaky injector wouldn't cause this type of issue because fuel flow is only controlled at the metering head and should be ZERO with the engine off.
You can try turning the mixture screw at the metering head anticlockwise, this will hopefully solve the problem (it is the IDLE fuel flow setting). Otherwise, the plunger is stuck in the fuel distributor, you can try to free it off but watch out for it leaking. If it's properly corroded in then it's game over and you'll need a new metering head. |
Judge
Posted: Sun Apr 14, 2024 5:25 am Post subject: |
Hello thanks for the reply,
Yeah I figured that out, but I'll be doing a whole flush of the car before taking the road with it anyway.
I investigated more and tried to use starting fluide to see if there was spark, and there aren't.
A friend told me to check for the ignition control module, that apparently comes stock under the driver's headlight. Except I checked and there's nothing there. Worse, it seems the ignition coil has a wire going to the radiator's fan?
I'm getting more confused, it seems a past owner messed with the car's electricity system.
I might stop working on the car for now as I have exams, but once I'm finished, I'll tow it in my house and properly rewire everything as it should be.
In the meantime, anybody knows of a tutorial to fit brake disc on the rear wheels? Former owner told me the rear drum brakes were done, so I might as well just upgrade those. |
Raize
Posted: Sun Apr 14, 2024 5:59 am Post subject: |
Judge wrote: |
Just ignore that for now. Need to get it running first.
Take off your distributor cap, does it look like this inside:?
Or does it have a component like this? (I can't even find a photo of 924 points distributor, it's so rare!)
Judge
Posted: Fri May 03, 2024 11:28 pm Post subject: UPDATE on my 924 not starting. |
Hello there everyone, it's been a while but I am now free to work on my Porsche full time.
A little bit of updates:
- I fixed a timing issue on the camshaft, as it wasn't sync with the crankshaft.
- I fixed the fuel pump (somehow), as now it starts with the ignition on)
- I dug a little more and this is the subject of the update:
I found on the 924board something about the ignition coil and whether is should have current and voltage when ignition's on.
Turns out mine has current when ignition's off, but when ignition on, it no longer has current.
Furthermore, instead of having 6V on 15 with ignition on, the ignition coil has 11V.
I don't really know what to do from now one. Should I put in a new ignition coil or should I dig more to find a cable issue?
I tried sanding the grounding points to be sure there's no issue there, and I did the same with most connections as it seemed a good thing to clear the connections.
Additionally: the RPM gauge doesn't move when trying to start. |
