Alternator not getting 12V
Noud
PostPosted: Mon Jun 17, 2024 7:59 pm    Post subject: Alternator not getting 12V Reply with quote
Hi, I have a 1982 924 that has a weird issue where the alternator won't charge unless I directly connect 12V to the alternators D+. The voltage regulator and ground strap have already been replaced. Does anyone know where the wire that connects to this D+ goes to or why it doesn't get power?
Thx!
Noud
PostPosted: Mon Jun 17, 2024 9:28 pm    Post subject: Reply with quote
Going from memory, there should be a circuit through the battery warning light in the dash, the combo gauge cluster, which makes the connection to start charging. Is your dash light bulb out/broken or disconnected?
Noud
PostPosted: Mon Jun 17, 2024 9:31 pm    Post subject: Reply with quote
That's what I thought as well so I tested the light and it works but somehow doesn't turn on when I turn the ignition on.
daniel
PostPosted: Tue Jun 18, 2024 9:13 am    Post subject: Reply with quote
Rev the engine to 4000rpm, if the regulator is faulty the alternator should charge.
Another thing to consider: I recently chassed down a voltage drop issue in my car that turned out to be the wire from the ignition barrel to the positive side of the coil. It looked fine, tested fine but dropped 2 volts!
1989 944 Cabriolet
