BillA
Joined: 27 Dec 2002 Posts: 170 Location: Syracuse, NY
Posted: Thu May 18, 2023 2:47 am Post subject: Where does it go? |
Does anyone have any ides where this connects to on the backside of the fuse block in the G section 1-9. it is the white wire I've seen posts related to this wire (white) and there doesn't seem to be a definitive answer. Trying to sort out no low beams. I think I've read every post about this subject still troubleshooting
Thanks.
 _________________ BillA
1981 931 |
bear924
Joined: 26 Jul 2005 Posts: 95 Location: South West Queensland, Australia
Posted: Thu May 18, 2023 9:09 am Post subject: |
Hi Bill,
I suspect we are both working on similar faults at the moment. The specific pin is the number at the point you've highlighted (your pics's resolution isn't good enough to see number and my drawings are elsewhere atm).
When I did my fault finding, I discovered that my pin had failed within the fuse box .. is short, the power come out of the fuse wasn't making it to the plug connection. |
