Gatornapper
Posted: Sat Mar 12, 2022 11:16 am Post subject: 931 Gas Mileage??? |
Ok, just got an idea of what my gas mileage is - my odometer is still broken.
Using my phone to track my mileage, I did a short test of 115 miles intentionally trying to stay out of the turbo. A disappointing 17.5 mpg.
I noticed that when I was enjoying the turbo, my mileage had to be horrible. Thus my test.
So what is the norm here for the 931 crowd? ok, not a crowd. What is normal for trying to keep out of the turbo? And what is normal when using the turbo about half the time?
Last question: HOW do I keep from it going into turbo mode? I try to accelerate slowly and shift at 3,000rpm. Any tips?
On the other side, what is it that kicks in the turbo? It doesn't kick in to about 3,500 rpm, right?
TIA,
GN _________________ '87 944 S, looks & runs like new - sold my sweet 931; '76 914 2.0 mostly restored; 2011 Porsche Cayman S in Meteor Grey, 3.4L, Softronics ECU tune 355+hp , PDK w/Sport Chrono. Got this thing for Porsche's....... |
chuck21401
Joined: 20 Feb 2005 Posts: 532 Location: Annapolis, MD
Posted: Sat Mar 12, 2022 11:41 am Post subject: Re: 931 Gas Mileage??? |
Gatornapper wrote: | Ok, just got an idea of what my gas mileage is - my odometer is still broken.
TIA,
GN |
I've never tracked my MPG but I'm sure it's not good. I'll put in 5-8 gallons at a time and go driving. I usually need to buy gas after 2 or 3 drives. But I'm usually trying to be on boost as much as possible.
I'd recommend getting a boost gauge if you really want to know. I can hear the turbo spooling up but it doesn't seem to be above 0 psi until after 2500 rpm or so. On the highway in 5th gear there is some boost with a touch of the throttle unless coasting.
I'm also using a manual boost controller set to 12-14psi, so that could make a difference too.
As I'm winding out 2nd and 3rd gear I have to confess I'm not worried about MPGs. And at the upper reaches of the RPMs I'm not looking at the gauges. lol. _________________ 1981 Porsche 931 w/S1 engine & g31 transmission. Water-cooled intercooler |
Posted: Sun Mar 13, 2022 6:07 pm Post subject: |
Wrong car for any thoughts on good gas mileage……if you’re considering this, buy a Prius
At best I get 20 UK mpg’s so that’s 250 miles at the very best out of a 50l tank. Usually far less on both counts. If it ain’t boosting, it ain’t worth driving. _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
Gatornapper
Posted: Mon Mar 14, 2022 6:15 am Post subject: Re: 931 Gas Mileage??? |
chuck21401 wrote: | Gatornapper wrote: | Ok, just got an idea of what my gas mileage is - my odometer is still broken.
TIA,
GN |
DITTO
In the plans. Just don't know when.
ALSO In the plans. Just don't know when.
As I'm winding out 2nd and 3rd gear I have to confess I'm not worried about MPGs. And at the upper reaches of the RPMs I'm not looking at the gauges. lol. |
DITTO! _________________ '87 944 S, looks & runs like new - sold my sweet 931; '76 914 2.0 mostly restored; 2011 Porsche Cayman S in Meteor Grey, 3.4L, Softronics ECU tune 355+hp , PDK w/Sport Chrono. Got this thing for Porsche's....... |
Gatornapper
Posted: Mon Mar 14, 2022 6:18 am Post subject: |
Not my goal - it's the right car for driving fun! Only new gas prices are going to make it a lot more expensive.
I was sensing that when I was enjoying the turbo, it was in the 10 mpg range - slurping gas fast.
Just wanted to know what a baseline was and if there was some adjustment I needed to make to something.
Thanks!
GN
Carrera RSR wrote: | Wrong car for any thoughts on good gas mileage……if you’re considering this, buy a Prius
At best I get 20 UK mpg’s so that’s 250 miles at the very best out of a 50l tank. Usually far less on both counts. If it ain’t boosting, it ain’t worth driving. |
Gatornapper
Posted: Mon Mar 14, 2022 6:20 am Post subject: |
You all use Regular gas or Premium?
I've been using Premium.
Can I use regular? I didn't know if the boost from the turbo required it - have seen nothing in manual or on car about needing premium........
Posted: Mon Mar 14, 2022 7:21 am Post subject: |
Gatornapper wrote: | You all use Regular gas or Premium?
GN |
You need the best RON you can get, so yes, premium. You think you have gas price issues……we’re paying near £2 per litre for premium, double your US prices _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
Posted: Mon Mar 14, 2022 5:28 pm Post subject: |
I felt I was getting excellent gas mileage highway flying but it was super thirsty being used as a DD for short errands..
Thing would just DRINK fuel boosting around town but high speed cruise all day long quite efficiently.. _________________ 80 Turbo - Slightly Modified |
Posted: Mon Mar 14, 2022 7:06 pm Post subject: |
IF your fuelling is of it doesnt matter how you drive, but yours should be lambda controlled on part load since its a us car, if it still works.
Normallt these cars (and many turbo cars, especially older ones) enrich the mixture quite alot at high load, hence its a good idea to noot boost it. They should be pretty good at just cruising, but i havent done that type of driving in any prolonged period of time in many years. But fast highway driving was around 25mpg if i remember correctly, though mine is euro s2 with 8,5CR, the compression ratio makes a significant different at part load fuel efficiency. According to the manual the euro s2 should do 27.4MPG at 74.5miles/hour, that would need the standard s2 turbo though, it definitely got a bit worse when i went up a size. I cant find any official numbers for the US version, it should be a bit worse though.
On track its about 3l/100km or 7.8MPG, will be nice now when fuel is at 2.2euro/litre
Do you have any vacuum leaks? clogged cat? Hows the status on the fuelling? _________________ 1980 924 Turbo
Posted: Mon Mar 14, 2022 8:13 pm Post subject: |
Used to get around 29mpg on my 951 bumpered 924 turbo S2 cruising around 75mph. My S1 931 did similarly, a bit worse due to worse aero...maybe 26?
My supercharged 924 does around 23mpg but the driving conditions are different now, i mainly did 85 on highways and i did a lot of mountain climbs with it...also..shorter gears of the NA, not as good aero and obviously the supercharger make up the difference...and except maybe carbs, there is no worse setup for mileage than short gears and supercharged.
Your 17.5 mpg result is clearly pointing that there is something wrong with your car.
EDIT fuel price here is:
1.8 eur / liter
that is 2.7AUD / liter or 7.3 USD / US gallon _________________ https://www.the924.com
Joined: 10 Dec 2006 Posts: 947 Location: Noosa Heads QLD Australia
Posted: Mon Mar 14, 2022 10:01 pm Post subject: |
+1 to Morghen above.
ROW S2 with 6.10 turbo and 8.5 CR easily achieved 30+ mpg cruising at 110kph
Race car with hybrid turbo/7.5CR/enriched fuelling barely achieves 8mpg.
Fuel prices in Oz: 98 RON $2.89 litre/94 RON E10 $2.29 litre _________________ 80/81 932/8 ROW |
Posted: Tue Mar 15, 2022 12:02 am Post subject: |
Funny to see the Turbos getting such mileage on track; with our old NA 924 (relatively mild engine build) we only get about 7mpg on track!
OTOH, my prototype, which is unbelievably faster, gets around 11-12mpg on track with it's little 1.0L GSXR motor!
Of course, while the 924 NA runs on ordinary 93 octane pump gas (R+M/2 method for the rest of the world!), at approaching $5/gal here in MI I think, the Gixxer needs to be fed a diet of 100 octane race gas, which was $10 USD/gal last summer when gas was cheap!
It's all relative... _________________ Vaughan Scott
Posted: Tue Mar 15, 2022 2:19 am Post subject: |
924RACR wrote: | Funny to see the Turbos getting such mileage on track; with our old NA 924 (relatively mild engine build) we only get about 7mpg on track!
It's all relative... |
I only measured my n/a once, and it was around 1.7 something l/100km, around 13.8mpg. Your tracks might be faster though with more time spent wot and less time spent cornering. The GT86 though was very good on fuel onnthe track, still had lots of fuel left after a day on track, even though the tank is smaller, where i normally need to fill up the 931 with cans after the same runtime
10usd per gallon of race gas! We are around the 10 mark here, for normal fill ups, at least it calmed down a bit now with the pieces. But thankfully i don't have to drive any long distances to work, and the main car runs mostly on electrons. _________________ 1980 924 Turbo
Joined: 28 Feb 2008 Posts: 1361 Location: Washington DC area
Posted: Tue Mar 15, 2022 3:05 am Post subject: |
6-8 MPG has been the norm for all my race cars (at 12.8 CO), the difference probably being better aero on some body shapes (356, 911, 924, 2002, Benz, VW). _________________ 1979 924 NA race car
1982 924 Turbo almost a PoS
Gatornapper
Posted: Tue Mar 15, 2022 11:35 am Post subject: |
Thanks all......my local driving is 50/50 hwy/suburbs.
Gonna do a highway trip tomorrow and will check hwy mileage.
After that I'll do a boosty run in the twisties where I live and check that.
As far as I know no vacuum leaks, all Haynes tests of CIS were spot on, engine could not run better it seems to me. Injectors are new. Purrs at idle, starts instantly regardless of ambient temp, turbo kicks in nicely around 3k rpm. A hoot to drive tho it doesn't corner as flat as my '76 914 which has no sway bars. Gonna replace sway bar bushings soon with hi-perform ones.
