Removing cracked dashboard and installing new Werk924 dash
chuck21401
PostPosted: Sat May 22, 2021 3:37 am    Post subject: Removing cracked dashboard and installing new Werk924 dash Reply with quote
I'm finally getting around to installing the new dashboard I bought from Werk924. (see: https://werk924.com/shop/armaturenbretter-dash-boards/)
I found two sets of instructions...of course the article on 924.org but also the early 944 instructions from Clarks Garage.
http://www.924.org/techsection/DashReplacement.htm
http://www.clarks-garage.com/shop-manual/body-26.htm
Most recently, Auto Anatomy produced this YouTube video on how to replace the blower motor, which of course you need to remove the dashboard to do. Here's the link: https://www.youtube.com/watch?v=NAgKnVIqAVc&list=PLukxB8bYuv7oLTVln6h0HqZLrWXi1n50X
Here's what we are starting with:
Currently I have a carpet on the dashboard to hide the cracks.
Here is the new dash from Werk924
The price included a dash protector
[/b]
1981 Porsche 931 w/S1 engine & g31 transmission. Water-cooled intercooler
PostPosted: Sat May 22, 2021 7:28 am    Post subject: Reply with quote
Wow, just wow. If I lived closer I'd come over just to get a whiff of that new car smell.
PostPosted: Sat May 22, 2021 10:09 pm    Post subject: Reply with quote
People have scoffed at the price of Thomas' repro dashes. But look at the quality in those photos.
Swapping is super easy. The only issue is being scared to nick, scratch or mark that perfect new dash.
Good luck.
chuck21401
PostPosted: Mon May 24, 2021 2:33 am    Post subject: Reply with quote
So far so good...taking my time. I'm learning that 40 year old plastic parts are brittle. I've had to made some new tabs with "Plastex" and fill some cracks. One small section of the center console fell apart as I was removing the switch for the electric mirror. I was able to repair that with Plastex as well. Source: https://www.plastex.net (also on Amazon, shipping is less)
I suppose I could just buy another HVAC panel Ebay (or not worry about it), but wanted to see if I could do it.
Missing tab circled. Using putty to make mold from the tab below.
Mix up the Plastex and drop mixture into mold
Allow to harden. Use razor blade to trim and emory board to sand down.
New tab
chuck21401
PostPosted: Mon May 24, 2021 2:35 am    Post subject: Reply with quote
I'm right around the corner. Drop by whenever.
Still waiting on videos of the 931 S3 in action.
chuck21401
PostPosted: Mon May 24, 2021 2:39 am    Post subject: Reply with quote
Almost ready to remove the dash.
chuck21401
PostPosted: Mon May 24, 2021 5:44 am    Post subject: Reply with quote
This is getting complicated.
Luckily installation is the reverse of removal.
jacobroufa
PostPosted: Mon May 24, 2021 9:56 pm    Post subject: Reply with quote
chuck21401 wrote:
New tab
Very nice!
1980 Porsche 931
1981 Porsche 924 Weissach
safe
PostPosted: Mon May 24, 2021 10:22 pm    Post subject: Re: Removing cracked dashboard and installing new Werk924 da Reply with quote
[/b]
Is it fibreglass framed?
How does the colour, shine and grain structure compare to the original?
/Magnus, Stockholm Sweden
Porsche 931 -79
Porsche 911 -77, 3.2 Targa
Porsche 911 -69, 3.6, Coupe
chuck21401
PostPosted: Tue May 25, 2021 3:17 am    Post subject: Re: Removing cracked dashboard and installing new Werk924 da Reply with quote
I believe that it is fiberglass. It feels very solid though.
Here are some comparison pictures. The old dashboard has some lighter brown highlights....not sure how to describe. Also not sure if that is the result of 40 years of sunshine. The texture is very similar to me.
But truthfully when I look at the old dash, the only thing I see are the cracks.
chuck21401
PostPosted: Tue May 25, 2021 3:25 am    Post subject: Dash Vents Reply with quote
Removing the side dash vents didn't go so well. I barely touched the tabs and they broke off. The plastic is so brittle!
Anyone have a source for mint condition, non-faded, brown dash vents?
Maybe I could find a nice set from an early 944?
These will work for now I guess.
PostPosted: Tue May 25, 2021 4:12 am    Post subject: Re: Dash Vents Reply with quote
This is a special German material found throughout our cars. The same material comprises many critical electrical connectors.
Its name is "Brittelsheiß."
chuck21401
PostPosted: Tue Jun 01, 2021 1:01 pm    Post subject: Reply with quote
Making some progress.
The new dashboard is in the car but still need to make some adjustments and still fighting with the center console. So many wires.
I also had the odometer on the speedo fixed while it was out of the car. Also replaced the ignition switch while I was in there.
As you can see, the side vents are no longer brown. I need to replace the trim piece for the headlight switch; that should be fairly easy to find in better shape. I replaced the trim piece for the hazards and rear window defogger....nice match.
chuck21401
PostPosted: Fri Jun 11, 2021 12:20 am    Post subject: Reply with quote
More progress. Still need to adjust the glove box a bit.
I installed the switch for the intercooler pump/cooling fan in the center console opposite of the stereo fader knob.
PostPosted: Fri Jun 11, 2021 3:52 am    Post subject: Reply with quote
So nice! I got to see one first hand recently in Bart's Martini Resto. Really nice dash
Chuck, that little mold idea was brilliant
