What are these.
BurialWings
PostPosted: Thu Apr 08, 2021 2:18 am    Post subject: What are these. Reply with quote
Putting the final touches on putting back together an engine, thing was already apart when I got it.
Have two "what the hell are these" things. One is a hole next to the air oil separator on the back side of the block. The other looks like a vacuum line of some sort possibly a/c related???? Could even be related to each other I'm guessing. That appears to have been sheared off at some point. Any help would be great.
PostPosted: Thu Apr 08, 2021 3:37 am    Post subject: Reply with quote
Is this a 2.5L?
BurialWings
PostPosted: Thu Apr 08, 2021 3:46 am    Post subject: Reply with quote
Yeah it's a 87 2.5
PostPosted: Thu Apr 08, 2021 4:32 am    Post subject: Reply with quote
On picture one, the larger hole looks like the AOS drain. The smaller hole is a capped off oil or water passage.
Picture two almost looks like an AC hard line, but it wouldn't have a standard clamp on it. Are we sure it's from this car?
BurialWings
PostPosted: Thu Apr 08, 2021 4:49 am    Post subject: Reply with quote
Okay so the smaller hole is the one in question. Wanted to be sure nothing went there before I put the AOS on.
As for the second pic, it very well might not be, but it was with the parts from it. I can't seem to find any where it would have sheared off from. If it's likely from the a/c then it's something I can figure out later, I just want to be sure it's not supposed to be plugging off any sort of vacuum.
PostPosted: Thu Apr 08, 2021 8:05 am    Post subject: Reply with quote
There is nothing like that in the 2.5 intake system.
anthonimartini
PostPosted: Thu Apr 08, 2021 1:33 pm    Post subject: Reply with quote
its a broken off exhaust probe port. i rip them off and weld them up.
saving a 1977 martini ... please help! (done)
87 924S GF's Daily
77 924 Safari (931 swap) daily
79 MochaSchwartz work in progress
formerly known as turbellion, lost password.
BurialWings
PostPosted: Fri Apr 09, 2021 12:01 am    Post subject: Reply with quote
Thank you! I searched that up and found the info I needed. I would have been trying to hunt down that problem for a lifetime.
anthonimartini
PostPosted: Fri Apr 09, 2021 2:17 am    Post subject: Reply with quote
lol no problem!
87 924S GF's Daily
