Posted: Sun Mar 21, 2021 1:36 am Post subject: |
MikeDanger wrote: | Can a Headgasket be "just barely bad" to cause this? |
Totally, classic HG symptoms (runs fine cold, then misses when warm). _________________ Toofah King Bad
- WeiBe (1987 924S) - 931 S3
- Shaggy (1980 931) - SOLD (unlucky, but tried hard
Posted: Sun Mar 21, 2021 4:22 am Post subject: |
I never experienced poor running with my barely bad HG.. Just some bubbles in my coolant after it warmed up..
You check your distributor cap and rotor situation?
Any bubbles in your coolant?
Coolant system hold pressure? _________________ 80 Turbo - Slightly Modified |
MikeDanger
Posted: Sun Mar 21, 2021 5:34 am Post subject: |
Fasteddie313 wrote: | I never experienced poor running with my barely bad HG.. Just some bubbles in my coolant after it warmed up..
Coolant system hold pressure? |
cap and rotor are new, Don't notice any bubbles, and the system seems to hold pressure, I did just swap to a 944 tank (used).
Wouldn't a blown Hg show a "washed" Spark plug? _________________ It was either this or a giant box of legos |
Posted: Sun Mar 21, 2021 5:42 am Post subject: |
Depends on the location of the damage. There are oil passages in the HG as well. _________________ Toofah King Bad
MikeDanger
Posted: Sun Mar 21, 2021 6:15 am Post subject: |
really don't want to hear this  _________________ It was either this or a giant box of legos |
MikeDanger
Posted: Sun Mar 21, 2021 6:30 am Post subject: |
Ok well, Im going to check the Injectors first, but following that, whats the steps you'd take to test for HG?
Should I run the car up to temp then check compression? or just do it cold? _________________ It was either this or a giant box of legos |
Joined: 14 Dec 2004 Posts: 1102 Location: Chicago-ish
Posted: Sun Mar 21, 2021 6:42 am Post subject: |
I don't trust spark plugs so at a minimum switch them around to see if the dropped cylinder, or "wetted" plug, follows the plug or stays with the cylinder
I think you where at #3 _________________ 1980 931 since 1989
MikeDanger
Posted: Sun Mar 21, 2021 9:36 am Post subject: |
Mike9311 wrote: | I don't trust spark plugs so at a minimum switch them around to see if the dropped cylinder, or "wetted" plug, follows the plug or stays with the cylinder
I think you where at #3 |
Well I cleaned/torched the plugs before I put them back, didn't keep them in order. _________________ It was either this or a giant box of legos |
MikeDanger
Posted: Sun Mar 21, 2021 10:30 pm Post subject: |
1. Control pressure has absolutely nothing to do with injector flow for any given plate position..
Control pressure adjusts plate position for any given airflow through/passed the metering plate.. It only adjust how easy or hard it is to move the plate, adjusting plate position vs airflow..
Drop your control pressure way down, feel the plate stiffness..
Raise the control pressure way up, feel the plate stiffness..
You will see..
2. Your injectors for one have terrible spray patterns and are also horribly uneven..
The one to the right seems the best.. Try that one on the right on all of the lines, and if it is always still the first one to pop off your fuel distributor is probably ok..
Replace those injectors.. Holy smokes they are bad..
No wonder it’s missing..
Maybe dump a bottle of tecron on a 1/4 tank of fuel and run those injectors into bottles for an hour, dump it back into your gas tank if it looks clean..
Let it sit overnight and do it again the next day..
My guess is though, those injectors are toast..
Maybe try blowing them out with air, even hold the pintails out with your fingernail and blow through them backwards..
You can try saving them, but they look pretty darn bad..
Nice videos.. Worth a million words.. _________________ 80 Turbo - Slightly Modified |
Posted: Sun Mar 21, 2021 11:19 pm Post subject: |
"safe" out of Sweden called it Nice
At least its not a head gasket! Injector issue is nice news
And...a big And...any build from now on is getting an injector check _________________ 1980 931 since 1989
MikeDanger
Posted: Tue Mar 23, 2021 7:16 am Post subject: |
Well I found 2 decent spraying injectors. replaced 3 and 4.
I First sprayed Seafoam DeepCreep penetrating lube through them with the straw. then tried them, took a second for them to "pop" then they sprayed a good pattern.
I reinstalled and used sealant on the spacer threads let it cure overnight.
Im about to go try and start here shortly. _________________ It was either this or a giant box of legos |
MikeDanger
Posted: Tue Mar 23, 2021 10:18 am Post subject: |
Well, Im keeping my fingers crossed; I started it and ran it for 5-6 min, and didnt hear a miss, and the AFR were steady.
Not sure that explains the sudden lack of power on take off I got on the last test drive, but I guess we'll see. _________________ It was either this or a giant box of legos |
