procyon
Joined: 09 Sep 2015 Posts: 64 Location: Peers Alberta Canada
Posted: Sat Mar 06, 2021 10:46 am Post subject: Starter removal issues |
I am having a hard time removing the top bolt on the starter. I have the bottom bolt out and I can just barely get a box end wrench on the top bolt's head but I have no leverage. I can't get an extension on the wrench for more leverage because the fender is in the way. Using a flex head ratchet I can get a bit more leverage and slip a snipe bar on that, but then by the time all the play is out of this setup I bump against the engine. I don't remember it being this hard the last time I pulled an engine. It's a 1980 NA if that matters. I have sprayed the threaded end with PB Blaster and Kroil.
Any suggestions? _________________ 1981 924 N/A (Now the parts car)
1980 924 N/A ( 5 bolt discs and better paint) MS II V3.57
2003 Subaru Baja
2021 Maxda CX-30 |
