Bending fuel lines
MikeDanger
PostPosted: Sat Mar 06, 2021 8:24 am    Post subject: Bending fuel lines Reply with quote
Can anyone comment on bending the metal fuel lines (from CIS to engine)
Im using an old fuel line as part of my DIY pressure tester, but I can't leave it in because it sticks straight up and can't close the hood. If I could put a 90* bend in it I could make it fit.
PostPosted: Sat Mar 06, 2021 9:01 am    Post subject: Reply with quote
There are cheap little brake line bending tools available as some auto parts stores and probably on-line.
1979 924 NA race car
1982 924 Turbo almost a PoS
MikeDanger
PostPosted: Sat Mar 06, 2021 9:04 am    Post subject: Reply with quote
so Im guessing bending by hand will probably make them collapse?
PostPosted: Sat Mar 06, 2021 10:02 am    Post subject: Reply with quote
I bent all mine by hand, a LOT of em..
See them in the link in my signature..
Pretty easy, just don’t try to make too tight of radius bends so you don’t kink them..
Make longer bends a little at a time..
Practice on a piece you don’t need to use?
I never kinked a single one actually, so in my opinion they don’t kink very easily at all..
MikeDanger
PostPosted: Sat Mar 06, 2021 11:13 am    Post subject: Reply with quote
how about reposting those pics of the permanent gauge mount?
PostPosted: Sat Mar 06, 2021 12:14 pm    Post subject: Reply with quote
Bending tool is cheap and does a great job.
PostPosted: Sun Mar 07, 2021 4:39 am    Post subject: Reply with quote
Here from 0:45 on..
https://m.youtube.com/watch?v=1wk3QW90cbM
MikeDanger
PostPosted: Sun Mar 07, 2021 1:12 pm    Post subject: Reply with quote
I was able to bend it by hand gently, mostly right at the CIS meter as it was one of the injector lines that was straight.
heres a pic of how I installed the gauge permanently.
PostPosted: Mon Mar 08, 2021 1:19 am    Post subject: Reply with quote
It’s likely you will get a very weird warmup when your WUR is not bolted to the intake to keep it “warm”..
Might start rich, lean out, then drift back rich..
