Juho
Posted: Thu Feb 18, 2021 2:48 am Post subject: Exhaust manifold flange |
Is there a exhaust manifold flange that fit 924 2.0 na. I plan on building my own exhaust manifold. i was looking at some vw flanges but i cant measure them so anyone knows? |
safe
Posted: Thu Feb 18, 2021 11:09 pm Post subject: |
Make your own, its not that difficult with a drill, angle grinder and a file or die grinder. _________________ /Magnus, Stockholm Sweden
Porsche 931 -79
Porsche 911 -77, 3.2 Targa
Porsche 911 -69, 3.6, Coupe |
Juho
Posted: Fri Feb 19, 2021 3:24 pm Post subject: |
im having hard time to find thick enough steel plate to make it from |
Posted: Fri Feb 19, 2021 5:29 pm Post subject: |
A small friendly shop next to me was also thinking about producing the complete exhaust for the 924, i even posted an offer but since nobody was interested they dropped the idea and did a lot of VW stuff instead _________________ https://www.the924.com |
safe
Posted: Fri Feb 19, 2021 5:59 pm Post subject: |
Juho wrote: | im having hard time to find thick enough steel plate to make it from |
Isn't there a local steel company, black smiting etc? Maybe someone that do water or laser cutting, that can do the entire job of cutting a flange?
Just a quick google and you can get steel plate bar from amazon.se https://www.amazon.se/Platt-st%C3%A5l-plattj%C3%A4rn-2000-l%C3%A5ngt/dp/B07GNLPP3N/ref=sr_1_2?dchild=1&keywords=plattj%C3%A4rn%2B12mm&qid=1613720634&sr=8-2&th=1
I'm sure Amazon or ebay ship to Finland too.
Can you read swedish? If not try do google translate this: http://ajden.se/ajden/flansar/index.htm
He makes custom flanges etc, If he hasn't got a CAD for it he can make one from a gasket.
At least he used to, send him a mail. _________________ /Magnus, Stockholm Sweden
Porsche 931 -79
Alleycat_Joe
Posted: Sat Feb 20, 2021 2:19 am Post subject: |
I have been regarding wastegate flanges as an option since they are close to the right size for the turbo head. Not sure on the NA specs as I am new. A lot of elbow grease with a file or a little time on a milling machine and four of these should be perfect if you're up to using separate flanges:
https://www.ecstuning.com/b-atp-parts/38mm-wastegate-weld-flange-steel-drilled/atp-fls-004~atp/
VW flanges are a very close option from what I've researched but I don't have any measurements. _________________ 1980 931 | 1981 240D 4spd |
