What is this large ground wire near the battery for?
mattaebersold
PostPosted: Mon Feb 08, 2021 8:10 am    Post subject: What is this large ground wire near the battery for? Reply with quote
Rebuilding a 931, and I see this wire near the battery... looks like a main ground, but the battery terminals are already there... this is just hanging out.
- does anyone know what this is for?
- how would I ground this? Just add a large end piece and bolt it to the body?
2005 Touareg V8
2006 530xi Wagon
931-1979
PostPosted: Mon Feb 08, 2021 4:16 pm    Post subject: Reply with quote
I think it´s the + to the startermotor
924 2,0 - 1982
PostPosted: Tue Feb 09, 2021 2:04 am    Post subject: Reply with quote
Oxygen sensor?
mattaebersold
PostPosted: Tue Feb 09, 2021 6:06 am    Post subject: Reply with quote
The starter did work before I tore down the engine, so I don't think it's that
2005 Touareg V8
2006 530xi Wagon
mattaebersold
PostPosted: Tue Feb 09, 2021 6:07 am    Post subject: Reply with quote
Paul wrote:
Oxygen sensor?
Interesting, so I should just put a connector on it and ground it to the body? Or somehow splice it into the negative battery terminal?
2005 Touareg V8
2006 530xi Wagon
chuck21401
PostPosted: Wed Apr 07, 2021 8:55 am    Post subject: Reply with quote
It might be a stretch but I've read that some have run an additional ground wire from the block to body ground near the negative battery terminal to help with mysterious grounding issues. This was written up in the most recent issue of Excellence magazine.
So another clue might be....where does the other end of that wire go?
1981 Porsche 931
