Transplanting 924 turbo engine on na
PostPosted: Mon Dec 14, 2020 8:02 am    Post subject: Reply with quote
GM pushrod V8..
PostPosted: Mon Dec 14, 2020 8:27 am    Post subject: Reply with quote
2.5 5cyl 07K engine code
safe
PostPosted: Mon Dec 14, 2020 9:21 am    Post subject: Reply with quote
K20/K24 is a really good engine, but 4 cylinders is to few if I was to do a non-Porsche swap.
5 cylinder, nah, too quirky.
A V6 sounds nice, can give you good performance and is quite compact.
/Magnus, Stockholm Sweden
Porsche 924 -79 NA, under EFI and turbo conversion
Juho
PostPosted: Mon Dec 14, 2020 3:58 pm    Post subject: Reply with quote
someone swapping a k24 to 924 in youtube
Juho
PostPosted: Mon Dec 21, 2020 4:20 am    Post subject: Reply with quote
Would this high compression engine be possible to build with off the shelf parts?
Juho
PostPosted: Thu Dec 24, 2020 8:45 am    Post subject: Reply with quote
I think this could be possible to make from off the shelf parts by using volvo rods, but finding pistons for 23mm is alot harder
safe
PostPosted: Thu Dec 24, 2020 8:52 am    Post subject: Reply with quote
Most pistons are 22mm so rebush the rods to 22.
Juho
PostPosted: Thu Dec 24, 2020 9:04 am    Post subject: Reply with quote
oh i didnt know this is possible, does this cost alot to do and can regular machine shop do it?
safe
PostPosted: Thu Dec 24, 2020 9:17 am    Post subject: Reply with quote
A regular machine shop can do it. A normal rebush would be about 50euro I think. Depends on if they can find a suitable bushing or can make one.
Have you found a Volvo rod thats longer than stock with the same big end?
Juho
PostPosted: Thu Dec 24, 2020 9:18 am    Post subject: Reply with quote
b230 be is 52mm and is 152mm long, longer than 924 rod
safe
PostPosted: Thu Dec 24, 2020 9:35 am    Post subject: Reply with quote
Big end seems wider on the Volvo rod?
Juho
PostPosted: Thu Dec 24, 2020 9:38 am    Post subject: Reply with quote
https://www.maxpeedingrods.co.uk/product/high-performance-volvo-b230-h-beam-connecting-rods-conrods.html?search=volvo%20b230
im looking at these rods
safe
PostPosted: Thu Dec 24, 2020 9:46 am    Post subject: Reply with quote
Ok, not the same dimensions as the b230 rodd I looked at, but still not the same as the 924. You must find a way to control side movement of the rod. Some engines like 924 does it by the big end, other my do it by the small end and piston.
Juho
PostPosted: Thu Dec 24, 2020 9:53 am    Post subject: Reply with quote
im out of ideas then hehe, just keeping it turbocharged might be easiest then
TJC
PostPosted: Fri Dec 25, 2020 1:39 am    Post subject: Reply with quote
I may be missing your definitive end game here, but if you want to keep it NA, and get some decent horsepower while sticking with the basic 924 2.0L engine look at the 924 SCCA D Production specs. With a few modern twists like EFI/ ITB's for instance, (although the original D/P fuel injection would be wicked if you could find one!), you can pull some decent power figures without reinventing the wheel or jumping through absurd engine swap or non Porsche engine parts in the stock 2.0L swap hoops!
Close to. equal, or possibly more HP than a stock 924 Turbo without the turbo parts, costs and cramped working condition hassles and a much more open and cleaner looking engine compartment.
All it take is time and money!
'95 BMW 318i/5 ..."Pearl"
Still on the Prowl!
www.ttrs1.com
Page 3 of 4
