1977 heater control wiring.
danewill924
PostPosted: Mon Nov 16, 2020 12:51 am    Post subject: 1977 heater control wiring. Reply with quote
i pulled the hvac blower switch out and it appears there are two male spades that come off the back. i also see two wires going to the blower motor itself. none of it was connected as the previous owner for some reason disconected it. anybody know how to run the wires for the blower to the switch? im assuming the power wire goes to the fuse box. haynes manual says E9 circuit 93. thanks
DANE WILLIAMS
MikeDanger
PostPosted: Mon Nov 16, 2020 6:54 am    Post subject: Reply with quote
probably should post this in the general section, rather than the turbo
