Oil volume
MikeDanger
PostPosted: Sat Nov 07, 2020 9:56 am    Post subject: Oil volume Reply with quote
I did an oil change recently, with 5w50 castrol edge, and the engine runs pretty good on it, never get a low oil pressure light, and idles just under 2 bar. But the valvetrain is a bit noisy, and I picked up a bottle of Redline 20w50, im planning to add. Id rather not drain any oil. (it leaks enough!) right now after sitting for a few days the dipstick reads right in the middle. Would it be safe to add 1qt to that?
PostPosted: Sat Nov 07, 2020 10:59 pm    Post subject: Reply with quote
No, that's only 1/2 qt low...
PostPosted: Sun Nov 08, 2020 3:46 am    Post subject: Reply with quote
Just want to add. I run 5W50 Castrol Syntec on the '82. The local autoparts store had a 'dump" sale on the rest of their Syntec for less that $3 a quart a few years back
I bought'em out
This is pre Edge syntec and I now have a good few years left of supply for the '82
Car runs great on it and pressure is good as well. Will eventually take a look at the camshaft for giggles. It was a good, no wear, matched tappet/lobe pull from an AMC head
PostPosted: Sun Nov 08, 2020 6:58 am    Post subject: Reply with quote
Valve train will remain noisy regardless of oil.....
PostPosted: Mon Nov 09, 2020 2:03 am    Post subject: Reply with quote
AMC cam the same profile?
PostPosted: Mon Nov 09, 2020 2:19 am    Post subject: Reply with quote
I believe so but I am not sure. There was a thread on this and somebody of forum past answered the question if memory serves but I don't have that archived.
We the car was purchased, the PO either acquired it in poor shape of at least attempted a partial restore. The engine was decent except the cam/tappets. Rear lobes were practically squared off
The AMC head I had on the shelf had a good cam and tappets so it was thrown in to get the car going. It remains
