931 S3
PostPosted: Mon Nov 30, 2020 4:15 am    Post subject: 931 S3 Reply with quote
On the way...
PostPosted: Mon Nov 30, 2020 7:15 am    Post subject: Reply with quote
Looking forward to more info
PostPosted: Wed Dec 02, 2020 6:52 pm    Post subject: Reply with quote
+924
PostPosted: Sun Dec 06, 2020 5:24 am    Post subject: Reply with quote
couldn't stay away
PostPosted: Wed Jan 20, 2021 4:19 am    Post subject: Reply with quote
Album.
PostPosted: Wed Jan 20, 2021 5:18 am    Post subject: Reply with quote
Album.
Awesome build!
Hope you’re enjoying it.
PostPosted: Sun Jan 24, 2021 9:33 am    Post subject: Reply with quote
So fast, so smooth.
Unreal.
For all the effort and expense I put into Shaggy, I could have built this car twice.
PostPosted: Sun Jan 24, 2021 5:47 pm    Post subject: Reply with quote
Applies to me building my red GTS wannabe vs buying a real CGT when prices were low. Or selling what was left of the wreck and buying a Cayman.
But i do not regret building my iron hero and you shouldnt either.
The iron lump will always have a place next to my heart...thats why i built the current one...its un-efficient and lacking in may ways but it compensates by simply making me happy.
PostPosted: Sun Jan 24, 2021 7:52 pm    Post subject: Reply with quote
Have you worked out the two vertical nose panels either side of the fmic need to be bent outwards to avoid the vents of the turbo badge panel??
Are you going to use the 944 turbo intercooler ducting? I would recommend it.
PostPosted: Mon Jan 25, 2021 12:35 pm    Post subject: Reply with quote
Congrats, nicely done!
PostPosted: Fri Feb 12, 2021 7:57 am    Post subject: Reply with quote
I'll be notching those vertical pieces for the time being, and hopefully add later the little side scoops used on the 931.
Not ducting at this time, although I may seal around the IC to force more air through it.
PostPosted: Fri Feb 12, 2021 7:53 pm    Post subject: Reply with quote
I bent my verticals outwards to clear the outer badge panel vents before welding them.
You should see OK cooling without the duct if its primarily used on the road with sporadic boost. The IC is hefty in size and weight and doesn't heat soak easily. Ducting may be needed if using in anger to help cool the IC more. Doing this on mine gives an IC outlet air temp circa 6-8degC above ambient with inlet temps on WOT over 100degC. Was higher without ducting.
I'll be going down the same route on the CGT race rep car too
PostPosted: Sat Feb 13, 2021 1:44 am    Post subject: Reply with quote
Interesting, thanks for the picture.
I'll let you know how it works. Keep in mind the 2.5 is much cooler blooded....
Cédric
PostPosted: Sat Feb 13, 2021 2:25 am    Post subject: Reply with quote
The effiiency of the intercooler is based on temperatures and flow. So running at 1 bar of boost on a 2l or 2,5l creates the same temp, but more air flow (due to the capacity) on 2,5 makes it a bit more challenging.
Except if you try to push the worst of the 931 turbos like the 2470, then it will be more heat to handle of course.
Time for a friday beer!
