stan_5150
Posted: Mon Jul 13, 2020 8:51 am Post subject: 924 Brakes - Master Cylinder? |
Good day. 1978 924 approximately 76K on it. Last time it had tabs on it was in 2002 and to my knowledge it hasn't been run since then. It was my dads and he always garaged it. Any.....
Brake pedal went to the floor, noticed that there wasn't any brake fluid in the system so I've spent my time bleeding all 4 corners. Fluid pumps, no air that I can tell, but pedal still goes to the floor. I'm thinking master cylinder but if anyone has any suggestions please let this noob know!
Thanks. |
Posted: Mon Jul 13, 2020 11:34 am Post subject: |
Sounds right.. _________________ 80 Turbo - Slightly Modified |
stan_5150
Posted: Tue Jul 21, 2020 5:48 am Post subject: |
Much appreciated! Anyone have a good suggestion for a parts source for a Master Brake cylinder for these? I've seen everything from a $75 rebuilt unit to $750 for a new one. Any/all suggestions welcome. Thanks again. |
Joined: 02 Nov 2002 Posts: 9463 Location: Southeast Wisconsin
stan_5150
Posted: Wed Jul 22, 2020 2:16 am Post subject: |
Great suggestions! Time to do some shopping and fixing. |
scm924s
Joined: 22 Oct 2010 Posts: 229 Location: Gloucester UK
Posted: Wed Jul 22, 2020 7:37 am Post subject: |
There was a change to the master cylinder about 78/9, the later ones were larger, also did away with the 2 brake light /fluid level warning light switches on the bottom of the m/cyl. At least on the euro spec cars. Early ones appear to be getting harder to find. _________________ 1984 n/a Ruby Red Metallic
1988 924S Guards red- sold
1986 924S Guards Red - sold
1984 n/a Black - sold
1980 n/a Le Mans#1 - sold
1980 n/a Le Mans#2- sold
1977 Martini - sold |
!tom
Joined: 28 Aug 2006 Posts: 1908 Location: Victoria, BC Canada
Posted: Fri Jul 24, 2020 4:36 am Post subject: |
The 78 still used pressure switches... _________________ 78 924 NA
5-lug |
stan_5150
Posted: Thu Aug 13, 2020 12:17 am Post subject: |
Anyone know where the best source is for a 924 master brake cylinder rebuild kit? |
stan_5150
Posted: Fri Sep 11, 2020 11:43 pm Post subject: |
Long shot question here....has anyone here used a part number 171 698 181 L Brake Master Cylinder Repair kit on their 924? I found the number here: http://www.924.org/parts/parts.htm but just trying to see if anyone has any experience with that part number. Thanks in advance. _________________ 1978 924 |
stan_5150
Posted: Tue Sep 15, 2020 11:58 pm Post subject: |
Hey all. I found a repair kit online with a part number that ends in a "-181H".
The one on the 924.org parts page is a "-181L".
What does the alpha character in the Part Number denote? Some sort of upgrade/downgrade?
Coco_Lev
stan_5150
Posted: Fri Sep 18, 2020 11:01 pm Post subject: |
Many thanks! _________________ 1978 924 |
