931 parts
PostPosted: Thu Aug 13, 2020 12:09 pm    Post subject: 931 parts Reply with quote
I haven't had a 931 in the shop for years, so it's time to get rid of some stuff as I find it. Everything new unless stated otherwise.
4 exhaust valves 931 105 406 02 SOLD
1 Victor head gasket set complete with valve seals
1 head gasket 047 103 383
first oversize main bearing set SOLD
J pipe
Used J pipe in good condition
Used oil drain plug
VDO temp sender installed in plug that installs in oil pan
Used green face oil pressure gauge
Used green face clock, not working
Valve cover gasket set
Oil pan gasket set
Air filter 931 110 121 00 ESP
Mahle KL 8 fuel filter
4 shift lever bushings 99992400240
8 Porsche nuts for turbo installation 999 084 611 02 (cost me $8.23 each decades ago)
4 930 111 191 13 gaskets
Bosch distributor cap
4 Fram PH2870A oil filters
Thermostat housing gasket 048 121 127 A
4 freeze plugs 059 103 113
Used DME with O2 box 931 617 101 00
Used DME no O2 box 931 617 101 00
Timing belt
A arms plastic bushings
More to come.
PM with offers include an email address for pictures.
PostPosted: Fri Aug 14, 2020 1:51 am    Post subject: Reply with quote
Have got a water pump?
Mike
'77 924
cricketdesigns.com
PostPosted: Fri Aug 14, 2020 4:47 am    Post subject: Reply with quote
no water pump.
Found new set of std rod bearings. SOLD
Post new topic   Reply to topic    924Board.org Forum Index -> Cars and Parts Wanted/For Sale All times are GMT + 10 Hours
