Bosch cis parts
Mikebuild
PostPosted: Sun Aug 09, 2020 3:33 pm    Post subject: Bosch cis parts Reply with quote
Hey everyone,
It was recommended that I post this question here, on the 924 board
I'm looking for possible sources for Bosch cis fuel injection parts. My 78 450sl has a broken "airflow sensor plate" (yes, the plate or disc in the air sensor bore; disinegrated) and I'd like to locate either a new or used plate. There are no part numbers on this one, but I've run across these numbers on the "bosch-classic" website F 026 T03 012; 3 430 105 005; 3 437 010 020; 0 438 120 062; 0 438 120 083; 0 438 120 114
Any ideas where to look? I've hit my local salvage yards, Pelican parts and a few others. Hoping to find a repair shop that still works on these Bosch fuel injection systems. Any help appreciated.
http://www.bosch-classic.com/en/internet/bosch_classic/produkte/motor_1/stauscheiben_1/stauscheiben___mit_teaser_1.html
Thanks, Mike.[/img]
PostPosted: Mon Aug 10, 2020 2:57 am    Post subject: Reply with quote
The round plate itself? Is it not metal?
Whole meter assembly on ebay for $300..
https://www.ebay.com/itm/76-80-MERCEDES-R107-450SL-W116-450SEL-AIR-FLOW-METER-CIS-INJECTING-0438120075/124262809799?hash=item1ceea400c7:g:BaQAAOSwja1fEGp1
Raize
PostPosted: Mon Aug 10, 2020 7:44 pm    Post subject: Reply with quote
If you knew the material and dimensions I bet you could get a new one laser cut for a lot less than $300. It's just a flat plate with a little hole in the middle!
