New guy, getting barn find 924 Turbo back up and running
Goto page 1, 2, 3, 4, 5  Next
Auto Anatomy
PostPosted: Sat Jul 11, 2020 2:39 pm    Post subject: New guy, getting barn find 924 Turbo back up and running Reply with quote
Hey all!
I'm a long-time Porsche guy (my daily is a 958 Cayenne diesel) who just picked up a 1980 924 Turbo.
Short story, I picked up the car after someone bought it for a race car and couldn't get it started. It was last registered in 2006, so probably hasn't run in around 14 years.
It looks like someone really hacked up the wiring on this car, so I've been going through and undoing the butchery.
Anyway, here's a video of the initial progress, with many more to come. I've got a ton of questions for y'all and hope you can help bring this gem back to life.
Sean
https://youtu.be/WHii7kvsQME
PostPosted: Sun Jul 12, 2020 12:34 am    Post subject: Reply with quote
Welcome to the forum! If you haven't seen these threads already, you may find them immensely helpful:
http://www.924board.org/viewtopic.php?t=22724
http://www.924board.org/viewtopic.php?t=28790
Good luck with the restoration!
jacobroufa
PostPosted: Sun Jul 12, 2020 2:44 am    Post subject: Reply with quote
Awesome! Glad to see someone with motivation to do videos featuring this car. It doesn't get enough love for how awesome they really are.
I hear the S1 is the better one to have, but maybe I'm biased also with a 1980...
Love the interior here -- Chuck on the board also has the brown, tan and tartan interior. Very cool!
Replace all the rubber bits as you said in the video and it'll be a much happier car. The CIS injection hates vacuum leaks.. I've got some leftover correct large braided hose (e.g. for the upper charge tube to the four-way yellow plated hard tube under it, and from the AAV to that same tube) if you want I can send you some at cost let me know... I had to buy several feet of it even though I only needed a few inches, and it's not cheap or widely available. I saw you got the small lines but not the bigger ones under the intake -- it's just easier with the charge tube off, to refurbish the entire loom.
http://www.924board.org/viewtopic.php?p=401098#401098
If you see on the top picture of this post, the two shortest, widest braided hoses on the four-way yellow hard pipe.. that's what I am referring to. And all the rubber elbows -- Guarantee those are source of some leaks too. The bigger diameter one is available through Porsche but for the smaller one the best fitting part is a Dorman elbow for a Ford I believe.. You'll also want to get the elbow and straight connectors on the turbo recirculation valve to the lower intake manifold -- that's a job for when you have things apart to do the timing belt or you'll be cursing a lot..
1980 Porsche 931
1981 Porsche 924 Weissach
Auto Anatomy
PostPosted: Sun Jul 12, 2020 7:03 am    Post subject: Reply with quote
Thanks everyone for the encouragement, I'm really excited to get this one back up and running.
Those are some phenomenal links and I'll definitely be going through them asap.
Jacobroufa, thanks for the offer, and I'll be reaching out to you in a bit to discuss the braided hose. I just redid a 66 Thunderbird and replaced around 200 feet of vacuum hose, so this car should be a breeze!
Sean
PostPosted: Sun Jul 12, 2020 12:32 pm    Post subject: Reply with quote
These cars are actually very easy to work on once you can come to an understanding of them..
Replace all vac lines..
CIS pressure tet.. (haynes)
Injector flow test.. (haynes)
And you're golden..
Auto Anatomy
PostPosted: Fri Jul 17, 2020 11:39 pm    Post subject: Reply with quote
FINALLY! After a 14 year slumber the 924 Turbo is back to life. It only took undoing a lot of “repaired” wiring and cleaning the fuel system again. Plus, I took it on my first drive.
It’s got a few issues that need sorting pretty quickly. First, the clutch doesn’t feel like it’s fully disengaging...I have to shift slow and even then it will grind sometimes. Perhaps it needs a new clutch.
Second, there’s a rattle at about 3000 RPM. It sounds like a heat shield, but is coming from the clutch area. Perhaps it’s related to #1 above.
Regardless, there’s still a lot to do. It’s has a wiring short (still) that drains the battery overnight and it needs a LOT of cleaning.
I do need a few parts, and hopefully someone can help.
If you're in the general Colorado area, I'm in need of a few parts for this car:
-Rear spoiler (just the center piece, but will take the whole spoiler if needed)
-Front windshield
-Rear view mirror
-Air filter housing straps
Let me know if you can help!
Thanks for the encouragement and advice, I really appreciate it!
Sean
https://youtu.be/R6qcx-iNbXI
Harm
PostPosted: Sat Jul 18, 2020 2:47 am    Post subject: Re: New guy, getting barn find 924 Turbo back up and running Reply with quote
FYI Clutch Master Cylinder rebuild kits do exist and start at a minimum price of ~€17,-
Like many others I’ve used the FTE product provided by Michael of sportwagenparts.eu
My 2 cents.
Good Luck.
Auto Anatomy
PostPosted: Sat Jul 18, 2020 2:54 am    Post subject: Reply with quote
Good to know. I briefly looked and couldn't find one, so went ahead and bought a replacement unit. I'd rather rebuild the original units if possible.
Sean
PostPosted: Sat Jul 18, 2020 3:24 am    Post subject: Reply with quote
+1 on the Cayenne Diesel!
1979 924 NA race car
1982 924 Turbo almost a PoS
Auto Anatomy
PostPosted: Wed Jul 22, 2020 10:06 am    Post subject: Reply with quote
Thanks for all the help. The Cayenne diesel is a great car, and such a workhorse.
As for the 924, the next step is going through all the brakes/suspension and getting them back to life. I'm afraid the car will need a clutch soon as the pedal disengages at the very top and doesn't feel like it's disengaging fully. The transmission will grind unless you shift very slowly and there's a vibration at around 3000 rpm that sounds like it's coming from the clutch area.
Sean
Auto Anatomy
PostPosted: Thu Jul 23, 2020 6:08 am    Post subject: Reply with quote
OK, strange thing happened today...
I was letting the car warm up (it has been running really well lately) when suddenly it just stopped. I thought it may have been low on fuel, but that doesn't appear to be the case. I've got good fuel pressure, but now no voltage to the coil. I let the car sit for a minute with the battery disconnected, checked voltage at the coil and it was around 6.7V. The car started back up again and then died about 3 seconds later. Now, no voltage to the coil.
I haven't had a chance to troubleshoot yet, but any immediate thoughts?
Sean
Auto Anatomy
PostPosted: Fri Jul 24, 2020 5:12 am    Post subject: Reply with quote
Looks like the fuel pump relay died, killing the tach signal. When I jumper across 30-87, the car fired right up.
More parts on order!
Sean
PostPosted: Fri Jul 24, 2020 8:26 am    Post subject: Reply with quote
tach signal could have died causing the relay to stop working..
tach still works fine with no FPR in, but FPR needs tach signal to turn the pump on..
Auto Anatomy
PostPosted: Sat Aug 08, 2020 11:10 am    Post subject: Reply with quote
Getting closer to having the abandoned 924 turbo as a daily driver!
https://youtu.be/sVT7-mCqTlc
Sean
PostPosted: Sat Aug 08, 2020 8:33 pm    Post subject: Reply with quote
Check the turbo overboost switch is earthing. If it’s not it kills the FPR.
Page 1 of 5
