Plastic used for 924 windshield washer fluid
ted von Kampen
PostPosted: Mon Jul 06, 2020 9:05 am    Post subject: Plastic used for 924 windshield washer fluid Reply with quote
Does anyone know the type of Plastic used to produce this windshield washer fluid container. I have some leaks in mine and I need to plastic weld the leak but I need the correct plastic type to get the correct welding rod. Thanks
safe
PostPosted: Thu Jul 09, 2020 12:38 am    Post subject: Re: Plastic used for 924 windshield washer fluid Reply with quote
There is usually a stamp somewhere on plastic stuff saying things like PP or PE.
Maybe there is somewhere on the container where you can scavenge some material?
ted von Kampen
PostPosted: Thu Jul 09, 2020 12:47 am    Post subject: Plastic material Reply with quote
Thanks for your answer. I have given the tank a through look over and it does not have that coding marked on it. I am thinking since this was made back in 1981, recycling and the need for the mark had not yet occurred.
