Joined: 23 Jul 2007 Posts: 1062 Location: The Netherlands
Posted: Sun May 24, 2020 3:52 pm Post subject: Different turbo mount 931??? |
I see some difference in turbo mounts(both same partnumber).
Difference is that the main hole is not in the center and the other one has a smaller hole for the oil feed.
Anybody know why?
https://ibb.co/Q8GPxxt _________________ 937 trackday car
937 DITC
Joined: 08 Jan 2010 Posts: 2101 Location: Somerset, UK
Posted: Sun May 24, 2020 7:42 pm Post subject: |
Believe mine is on the left....one on the car and spares
Bolt holes on the right look further apart in the pic? _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
Posted: Mon May 25, 2020 12:57 am Post subject: |
I have spent wayyyy to much time fondling turbo mounts on my aluminum mount project
I realized all too late a detail. The that hole doesn't line up with the drain on the K26 center section. Its offset one to the other
The simplest solution is to chamfer, or in this case, make that hole larger
It does look like the mount holes are farther apart but it wouldn't surprise me if its just the picture. The one on the left looks like it has larger holes.
Its hard enough to put these on a turbo since it hits the part of the turbo body. Larger mount holes allow more tilt during install. The one I scanned for my mount was notched by the PO
Most, if not all of my iron mounts, look like the one on your left.
The camera is playing tricks here too. This is also an early picture. Once I saw the offset drain, I increased my center hole diameter. I also made cut outs for mounting in the back part (not shown here)
 _________________ 1980 931 since 1989
Posted: Mon May 25, 2020 5:44 am Post subject: |
So the left one is the one to use? _________________ 937 trackday car
937 DITC
Posted: Mon May 25, 2020 9:44 am Post subject: |
I would say yes. The larger hole version seems to be the only ones I have. Found two more
Obviously not holding it perfectly. It was dark
