Audi engine swap
H2OSB
PostPosted: Thu May 14, 2020 7:57 am    Post subject: Audi engine swap Reply with quote
While I wait to see if anyone has any rear disc brake ideas in my other thread I'll ask a question about a bucket list swap I've always been intrigued by. Anyone on here done or know of someone who's done an Audi 5 cylinder turbo engine into a 924? 944 suspension and brakes at that engine would make a fun car.
johnL (aka H2OSB)
www.superbeetlesonly.com
PostPosted: Thu May 14, 2020 9:32 am    Post subject: Reply with quote
Yeah.. The bell housing even fits right for some of them, I think the 80's turbo 5cyls but I'm not sure..
PostPosted: Thu May 14, 2020 3:55 pm    Post subject: Reply with quote
Boost Brothers
Motorwerks Racing (although thatís the 1.8t)
A few others done it. A nice one in Sweden. But many start a well intentioned engine swap and then fail to complete it.
Raize
PostPosted: Thu May 14, 2020 7:56 pm    Post subject: Reply with quote
Those engines are so expensive now it's hardly worth it. The 1.8T makes more sense.
1981 N/A daily driver with:
Headlight relays. Vacuum gauge. Cold start switch. Kill switch. Ported cylinder head, intake and 944 exhaust. Brake booster venturi delete. 53/35mm throttle body. M62 supercharger mounted but not connected
jacobroufa
PostPosted: Thu May 14, 2020 11:24 pm    Post subject: Reply with quote
AFAIK VW 4/5 cylinder motors of the last several decades all use the same bell housing, so you could probably do a modern 2.5L I5 swap if you were set on having an odd number of cylinders -- this was used up until recently as a base model motor in the states in the Golf/Jetta and a highly tuned variant of it lives in the Audi TT-RS.
1980 Porsche 931
1981 Porsche 924 Weissach
Shurick
PostPosted: Fri May 15, 2020 3:44 am    Post subject: Reply with quote
One guy from Belarus done it, and done quite well.
Under the hood:
Underneath:
It's not even close to the top speed, BTW:
And moreover, here's a thread from right here: http://www.924board.org/viewtopic.php?t=44218
WBR, Shurick
'86 924S -- R.I.P.
https://www.instagram.com/ru_pacecar/
PostPosted: Fri May 15, 2020 6:02 am    Post subject: Reply with quote
400bhp and this noise........sure its worth it!!
https://youtu.be/uIDH4sx1iIs
https://youtu.be/z9siRWTyBew
