Rear Crankshaft Seal
Schwami
PostPosted: Thu Apr 23, 2020 4:43 am    Post subject: Rear Crankshaft Seal Reply with quote
Hey 924
I have a parts ordering problem.
I'm looking for the rear main seal and am not finding the correct one.
Are the "D" and the "K" issues the same?
059 103 051 D is from the Porsche parts list
059 103 051 K is from the internet.
thanks
1979 924 Diamant Zweischicht.
Serial # 9249201031
XG 309 543 engine code.
1995 ford taurus wagon
emoore924
PostPosted: Fri Apr 24, 2020 8:44 am    Post subject: Reply with quote
The letter following the part number usually means the earlier part number has been superseded. So a K comes after a D. For something like this, since it is so cheap, if Porsche still has it, I'd buy the factory part.
I find it a bit strange that Porsche would list an earlier number than an internet part.
Schwami
PostPosted: Fri Apr 24, 2020 9:38 pm    Post subject: Reply with quote
that is the weird part. it shows the part number for modern VWs golf and toureg,,,d is for the 924 and the K is for modern cars and stuff.
just want to buy the right one or if they are interchangeable
Serial # 9249201031
Schwami
PostPosted: Sat May 09, 2020 4:30 am    Post subject: Reply with quote
***************************update*************************
got the rear main seal and it is a match.
anyone know of a good place to buy replacement heater and coolant hoses?
$40 each is a lil steep!!!
Serial # 9249201031
PostPosted: Sun May 10, 2020 3:20 am    Post subject: Reply with quote
Perfect, THanks!
Its all these differing PN's for the same thing. Just ordered one out of the UK a week ago but this helps big time, thank you
PostPosted: Fri May 22, 2020 5:43 am    Post subject: Reply with quote
So a warning...
059 103 051 D Is perfect
059 103 051 K ...is the wrong size
Two of us ordered a few from here and there and so far this has been the case
If you order with the K you get a smaller seal. D is spot on
Strange but so far true
JTGarage
PostPosted: Sun May 24, 2020 8:22 am    Post subject: Reply with quote
So quick question... I also ordered a rear main from national that was a "k" and it wasn't close to my original. (78' NA). Where did you order your new "D" seal from? And any chance you've sourced a pilot bearing as well? I am struggling on finding those parts. Thanks!
78' 924 2.0l - Bonestock ---> Rebuilt
PostPosted: Sun May 24, 2020 9:53 am    Post subject: Reply with quote
Ebay
You can get the pilot bearing there as well
https://www.ebay.com/itm/Crankshaft-Oil-Seal-Ref-059-103-051D/323828588331?hash=item4b65b01f2b:g:8dgAAOSwNINc-u11:sc:USPSPriorityFlatRateEnvelope!60555!US!-1
...and pretty sure this is the pilot bearing. NA style which is what I think you need
https://www.ebay.com/itm/Porsche-912-914-924-70-82-Pilot-Bearing-INA-111105313A/272636309597?epid=1437406400&hash=item3f7a63f05d:g:o2oAAOSwN6JY9naG
