Supercharged 924 NA
gegge
PostPosted: Thu Apr 30, 2020 4:39 pm    Post subject: Reply with quote
Would it be possible to pre-charge the Roots with a turbo?
Carl Fredrik Torkildsen
PostPosted: Thu Apr 30, 2020 5:18 pm    Post subject: Reply with quote
Yes, it is possible to help out a 931 turbo in lower rpm but not easy.
I was actually thinking about my old 924 turbos when i first drove this supercharged 924 as there is boost right from idle...or the milisecond you open the throttle you are already on boost regardless of the RPM.
It feels like my Cayman in terms of responsiveness.
I still have my 931 engine and i'll test-fit the charger on that engine to see what would be needed to make it work for the 931 as well.
Until then, i'm improving the system every day a little bit.
I want to drive it again during this weekend with a wideband and data logging on so i can WOT it.
Sealing between the two tubes is done by flush fit and an oring.
Ruby-sh 924
CÚdric
PostPosted: Thu Apr 30, 2020 6:43 pm    Post subject: Reply with quote
Great that you put this project on here aswell! We ve been discussing it alot during the process so I have nothin more to add
I think i sent these before to you, but could be fun to add here, would be interesting to see if those performance numbers are close to what you will end up with in the end. According to the article they used water injection to mitigate detonation, hopefully it will be enough with 98octane fuel for you to get to the same point.
┤80 924 Turbo
PostPosted: Thu Apr 30, 2020 8:12 pm    Post subject: Reply with quote
Cedric, thank you for the outstanding level of input, greatly appreciated as always!
In comparison to that old-school supercharger i expect no need for water injection or any type of cooling because of the following differences:
-lower boost level (5 psi vs 7psi)
-much better fuel today vs back then
-much more thermally efficient supercharger
-fuel injected instead of carbs
-charger is not throttled
Ruby-sh 924
CÚdric
PostPosted: Thu Apr 30, 2020 11:22 pm    Post subject: Reply with quote
Yeah, i think there is much better chances for your setup with todays 98octane and better supercharger. And you also have a wideband to tune and measure with, which is a massive advantage.
┤80 924 Turbo
gegge
PostPosted: Fri May 01, 2020 4:40 am    Post subject: Reply with quote
I still don┤t understand the Butera solution. The k-jet (CIS) was capable of delivering fuel at the right A/F ratio. Why even consider (ONE) carb? And what happened to the runners?
The M45 presented here is by far the best hp per buck ever spent!
CÚdric
PostPosted: Fri May 01, 2020 4:52 am    Post subject: Reply with quote
I think the kjet was just new and scary, and they where used to carbs, probably not a fully rationale decision. Yeah, runner length was slightly compromised to say ar least
┤80 924 Turbo
PostPosted: Fri May 01, 2020 6:20 am    Post subject: Reply with quote
dunno why carbs..but they also ditched the cam cover
Ruby-sh 924
joewest
PostPosted: Sat May 02, 2020 3:42 am    Post subject: Reply with quote
Awesome upgrade!
'79 924 Track Prepared (currently under supercharger upgrade)
'80 931 Daily Driver
"The number of posts in my profile may represent the number of times I have screwed something up...and admitted it here."
PostPosted: Sat May 02, 2020 6:20 am    Post subject: Reply with quote
Second generation of functional prototypes now on the car.
Assembly ease much improved but room for better.
I still dont have an AFR on the car but seeing the plugs look good and only boosting a maximum of 0.2bar its safe to drive a bit lively...no WOT and no higher than 4500RPM tho.
Here is a short video of just driving around.
Its without question considerably quicker than when NA, revs up faster.
Gets up and goes instantly, no lag, no waiting for boost or rpms to increase.
pedal = GO
My butt dyno is that on a technical circuit it would be quicker than a standard 931 because of how quickly it picks up after slowing down for a corner.
Its nowhere near as dramatic as an early turbo, it feels and drives like a big NA...but sounds nothing like a NA. Video is poor quality but you can have an idea.
I suggest loud volume as the recording isnt very loud.
Car on toyo proxes, and ambient temp was approx 22deg C.
https://youtu.be/VxjylhPUoYs
Fueling looks decent so far, we'll see how it behaves on WOT and higher RPM after i hook up the AFR.
Ruby-sh 924
PostPosted: Sat May 02, 2020 8:35 am    Post subject: Reply with quote
It does sound pretty quick..
Sndtech
PostPosted: Sat May 02, 2020 3:44 pm    Post subject: Reply with quote
Real sweet .. sounds great and seems very responsive with instant power..
Manny-
1977 924 Martini |1979 924 N/A Dolomite Grey | 1980 924 N/A Minerva Blue
PostPosted: Sun May 03, 2020 3:24 pm    Post subject: Reply with quote
Cool video!
937 DITC
Euro924S2
PostPosted: Mon May 04, 2020 10:44 pm    Post subject: Reply with quote
Great work mate! The low down torque of the SC is it's best feature. It also makes it very predictable in the wet.
Keep the updates going!
Cedric, where did you find that article on the old SC kit? would love to read that if you have a link or higher quality image of the text?
CÚdric
PostPosted: Mon May 04, 2020 11:05 pm    Post subject: Reply with quote
Its in the "924 Gold portfolio" book, I can make a scan of it, but every 924 owner should have that book anyway
┤80 924 Turbo
Page 2 of 4
