Brake switch swap
Boogieman28
PostPosted: Sat Jan 25, 2020 11:00 am    Post subject: Brake switch swap Reply with quote
I put on the newer style master cylinder without the pressure hook ups. I got the brake switch mounted up i was wondering which colored wires go where I have a blue and gold wire a red and white and a red and brown or black. there are 2 of each so 6 wires total but only 2 terminal connections on the new pedal mounted switch. What is the easiest was to run the wires and what wires connect where?
dogleg5
PostPosted: Thu Apr 09, 2020 10:47 am    Post subject: Reply with quote
I see this thread is a few months old, and I can't help you on the wiring, but was looking at doing the reverse of what you did, minus the rewiring, because I found a m/c for an '80 924 for cheap and want to put it in my 82. From what I've seen/read they are the same except for the brake light switch setup. I'm guessing it worked out for you as far as brake function/performance?
