Different turbo mount 931???
PostPosted: Sun May 24, 2020 2:52 pm    Post subject: Different turbo mount 931??? Reply with quote
I see some difference in turbo mounts(both same partnumber).
Difference is that the main hole is not in the center and the other one has a smaller hole for the oil feed.
Anybody know why?
https://ibb.co/Q8GPxxt
937 DITC
PostPosted: Sun May 24, 2020 6:42 pm    Post subject: Reply with quote
Believe mine is on the left....one on the car and spares
Bolt holes on the right look further apart in the pic?
PostPosted: Sun May 24, 2020 11:57 pm    Post subject: Reply with quote
I have spent wayyyy to much time fondling turbo mounts on my aluminum mount project
I realized all too late a detail. The that hole doesn't line up with the drain on the K26 center section. Its offset one to the other
The simplest solution is to chamfer, or in this case, make that hole larger
It does look like the mount holes are farther apart but it wouldn't surprise me if its just the picture. The one on the left looks like it has larger holes.
Its hard enough to put these on a turbo since it hits the part of the turbo body. Larger mount holes allow more tilt during install. The one I scanned for my mount was notched by the PO
Most, if not all of my iron mounts, look like the one on your left.
The camera is playing tricks here too. This is also an early picture. Once I saw the offset drain, I increased my center hole diameter. I also made cut outs for mounting in the back part (not shown here)
PostPosted: Mon May 25, 2020 4:44 am    Post subject: Reply with quote
So the left one is the one to use?
937 DITC
PostPosted: Mon May 25, 2020 8:44 am    Post subject: Reply with quote
I would say yes. The larger hole version seems to be the only ones I have. Found two more
Obviously not holding it perfectly. It was dark
