Need 931 front sway bar body bracket dimensions
Mikko
PostPosted: Sun Mar 29, 2020 5:01 pm    Post subject: Need 931 front sway bar body bracket dimensions Reply with quote
Hello,
I am fitting a 931 type front sway bar and would need the dimensions for the brackets welded to the front frame/body.
Most helpful would be to know the size and spacing for the bolts and their location, let's say from the beginning of the front frame beam. Height from under the front beam to the flat area for the bolt is also important. Also, if someone has cut those off a scrap body I would also be interested.
Thanks in advance, once again and stay healthy. Us living in Finland are in partial lockdown due to corona... Luckily garage is in the basement and can work from home office
Br, Mikko
