Wastegate control line for Tial wastegate
bureau13
PostPosted: Wed Feb 05, 2020 11:54 am    Post subject: Wastegate control line for Tial wastegate Reply with quote
I was able to acquire a used Tial F46 for less than the price of a new diaphragm for my stock wastegate, so as soon as I get the time, I will be swapping them.
I'm pretty sure I can't use the stock control line without hacking it up, which I'd prefer not to do. Is there a preferred type/size of line to use? Silicone, or is something like fuel hose preferred? I know the Tial connection is a hose barb, so I assume I could just get one to mount on the charge pipe in the stock location and then run the line between them, if I can find something that screws in the stock location. I don't know that I want a long length of daisy-changed adapters, has anyone else done this? Surely this is not that uncommon...
1986.5 Silver 928S
2007 Hummer H3 (Daily Driver)
Past lives (I miss them all):
2004 RX-8 (Wrecked)
1993 RX-7 (Sold)
1987 RX-7 Turbo II (Sold)
1985 RX-7 GSL (Stolen)
PostPosted: Wed Feb 05, 2020 7:32 pm    Post subject: Reply with quote
Ideally find a spare hard pipe and metal fittings at the waste gate end or get one made by a hydraulic hose company using brake line or similar.. It gets very hot in the waste gate area and could melt a rubber/silicone hose. Just cruise sees EGT's over 650deg. You will then overboost with a split hose. Silicone is fine on top of the engine
bureau13
PostPosted: Thu Feb 06, 2020 1:37 am    Post subject: Reply with quote
Ahh. Good point...that would be bad. Any idea what size the stock banjo bolt fitting at the wastegate is? I've been assuming it won't fit the Tial, but supposedly the F46 was designed to be a replacement for the 930 wastegate (which we have) so...maybe worth checking, anyway.
1986.5 Silver 928S
2004 RX-8 (Wrecked)
1993 RX-7 (Sold)
chuck21401
PostPosted: Thu Feb 06, 2020 8:52 am    Post subject: Reply with quote
Couple of thoughts:
1. The Tial 46 WG is discussed on many threads on this board, you might check over there: http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/
2. This page has links to drawings:
https://tialsport.com/index.php/tech-wastegates/31-wastegate-dimensional-drawings
F46
https://tialsport.com/documents/w3_tial_46_dim.pdf
Looking around...appears that the Tial has 10mm banjo bolt; I believe that the banjo bolt for the 931 WG (900 175 020 02) is 12mm.
https://sierramadrecollection.com/hollow-screw-12mm-x-24mm-911-930-78-89-p21065.html
1981 Porsche 931
bureau13
PostPosted: Sat Feb 08, 2020 2:26 am    Post subject: Reply with quote
Thanks for that info!
1986.5 Silver 928S
2004 RX-8 (Wrecked)
1993 RX-7 (Sold)
