Tallgraham
Posted: Sun May 17, 2020 6:46 pm Post subject: Head scratching problem! |
Hi all
I have a 82 924N/A that I bought as a wreck and have got it back on the road. The fuel system had been left dry for years and after much removing, cleaning it's all up and running, new Injectors, accumulator, pump but I have a bizzare issue...
Hot start, tried everything, connected up fuel pressure gauge to check pressures and everything is within spec, and it'll fire hot every time. Disconnect the gauge and reconnect the fuel lines, won't start hot...
Is the gauge acting like an accumulator? I cannot figure out where this issue is now!
Thanks in advance. |
