Taking off wheel hub to get rotor off
After_Thought
PostPosted: Sun Jan 12, 2020 10:39 am    Post subject: Taking off wheel hub to get rotor off Reply with quote
I'm trying to take the wheel hub (I think that's what it's called) to get the rotor off but not matter what I try it won't come off. How do I get it off? Any tips?
[/code]
PostPosted: Sun Jan 12, 2020 1:01 pm    Post subject: Reply with quote
What have you done so far to remove the rotor on your 78 924?
After_Thought
PostPosted: Mon Jan 13, 2020 5:51 am    Post subject: Reply with quote
I think everything I need to. Calipers off and now stuck on I think it's called a grease cap. Do I need to do anything else to get this off? I know the driver's side has the c clip for the speedometer thing. But is there a bolt I'm missing to take these things off? Or are they just crazy rusted on
PostPosted: Mon Jan 13, 2020 7:15 am    Post subject: Reply with quote
A big pair of channel lock pliers to grip it and yank it off.....YMMV
1979 924 NA race car
1982 924 Turbo almost a PoS
After_Thought
PostPosted: Mon Jan 13, 2020 8:00 am    Post subject: Reply with quote
Think so? Lol. I'll give it another shot tomorrow. Just wanted to ask before j pull to hard and brake something
PostPosted: Mon Jan 13, 2020 9:15 am    Post subject: Reply with quote
I take a small flat blade screwdriver and tap it between the cap and the hub in a couple of spots once it moves thus a bit twist the blade to pry it out.
Mike
'77 924
cricketdesigns.com
PostPosted: Mon Jan 13, 2020 9:49 am    Post subject: Reply with quote
What Mike said too.
