ARP Rod Bolts Group buy?
PostPosted: Sat Dec 14, 2019 7:01 pm    Post subject: Reply with quote
safe wrote:
Its NEVER cheep to properly rebuild an engine, regardless the cost of the vehicle.
This is the downfall of the 924, it costs $1000 so the hillbilly who owns it doesn't want to by 4 new good tires, he buys 3 different kind of used tires. A relay fails, that costs money, he has a switch left over from a tractor. Lets put that in, lets drill a hole in the dash for it... etc.
Soon this car is a pile of junk tons of "customisations" that gets left in a field to rust away.
safe
PostPosted: Sat Dec 14, 2019 7:53 pm    Post subject: Reply with quote
Fasteddie313 wrote:
safe wrote:
Lighter pistons would be better over all for the engine.
My problem is that I would need bolts in order to change the pistons in any 2.0 shortblock.. Be it my current block, or more likely the replacement when I finally blow mine up..
Might be cheapest just to find another 931 engine to blow up, or a 2.0 shortblock if my head survives the inevitable catastrophy, but would need the pistons replaced, thereby requiring new rod bolts $$..
This just seems ridiculous money for some bolts.. Head studs are half the price..
We already know a lot can be ground off our rods to save weight and they are still plenty strong..
Why can't we find some more available and sanely priced bolts to do the job, and possibly even modify the rods to work with them?
The rods could possibly be reemed to take a slightly larger diamiter bolt?
The rods could possibly be modified where the head of the bolt meets the rod?
M10x1.0 Porsche Rod Bolt
They are 10mm dia?
What is so complicated about finding bolts to fit these holes?
BMW M10 rod bolts are 10mm
https://www.summitracing.com/parts/arp-201-6304/overview/
$108
Too short? Take some material off the rods so they fit?
10mm=0.393701"
7/16"=11.1125mm
Ream the holes out to 7/16?
49 results of cheap rod bolts in 7/16..
https://www.summitracing.com/search/part-type/connecting-rod-bolts/thread-size/7-16-in?N=thread-size%3A7-16-in&SortBy=Default&SortOrder=Default
ARP has all sorts of 10mm bolts..
https://arp-bolts.com/kits/bulk.php?PL=89&M=2&W=*&D=8&P=15&WS=13
Can't make anything fit?
Anything made in small batches will be silly expensive. If ARP had something that would fit straight on, like the head studs do, they would just sell you that. I think its almost crazy that they would just 10 sets.
Modifying the rods foe a "standard" ARP bolt, its interesting but way out my comfort zone both skill and tool vise. Its not some job for a drill press and a grinder.
A rod bolt is not just a bolt, there is a reason the fit of the bolt is really tight, it guides and locate the rod cap very precisely.
A machine shop could probably do it but what would the cost be?
If the rpm is kept to the stock rev limiter I would be much much more comfortable with reusing the so called one time use stock bolts.
The price for 931s will rise. In Europe you find rough ones below $10000, really nice ones are closer to double that.
Money invested properly in a 931 will pay back.
TJC
PostPosted: Sun Dec 15, 2019 1:52 am    Post subject: Reply with quote
They are 10mm dia?
$108
10mm=0.393701"
7/16"=11.1125mm
This is the kind of thinking that fostered the "hot rod" age from back in the 40's and 50's here in America and I for one applaud it. I have to agree, there probably are other alternatives out there and something that could be explored. As I mentioned in my previous comment there may even be a different rod that could be adapted. On a side note, I have seen many references about the 944 issues with crappy rod bearing availability that has led to modifying the Porsche rod to take a much better bearing that is a Toyota, (I believe), application originally.
Bottom line folks, where there's a will, there's a way !!!
'95 BMW 318i/5 "Pearl"
'80 Porsche 924 Turbo...Save or Part?
'86 Porsche 944 Turbo...Parting, Not Much Left!
'87 Porsche 944 NA "Liebchen"
Still on the Prowl!
www.ttrs1.com
PostPosted: Sun Dec 15, 2019 5:30 am    Post subject: Reply with quote
I have wondered about other bolt use also. I have put out a call to local race group for a BMW bolt to see close it would be, we have 5 or 6 BMW 1600-.2002's around and have several blown motors this year.
Mike
'77 924
cricketdesigns.com
PostPosted: Sun Dec 15, 2019 6:32 am    Post subject: Reply with quote
M10 bolts are...
Underhead Length (in):2.330 in.
Underhead Length (mm):59.18mm
How long are 924 bolts?
M10= Rod Bolt Head Style:E
What do 924 bolt heads look like?
PostPosted: Sun Dec 15, 2019 8:19 am    Post subject: Reply with quote
924 bolt heads are what I'd consider a very basic round head, like K or W.
Fine, you made me do it... photo album with some very recent pics of rod bots, intact and busted...
https://www.facebook.com/photo.php?fbid=10212999631540325&set=a.10212999625340170&type=3&theater
There's one pic in there that shows just the bolt head, after being snapped off the end of the rod (showing the Kamax 12.9 designation)... and another that, in context, shows the loose bolts.
PostPosted: Sun Dec 15, 2019 9:28 am    Post subject: Reply with quote
Measured a used bolt at 65.5mm OA length with a head thickness of 5.0mm.
Read some other sites that said that if switching rod or main bearing bolts the bores must be resized due to the different clamping pressure. I did the calcs and the clamping pressure of the stock bolts at 43 ft lbs torque dry is 431 lb. This based on at measured diameter of 0.3225" on the yield strength of the used grade 12.9 bolt.
Mike
'77 924
cricketdesigns.com
PostPosted: Mon Dec 16, 2019 1:17 am    Post subject: Reply with quote
M10 bolt
65.5-5=60.5-59.2= difference of M10 bolt = 1.3MM shorter
And your used bolt might even be stretched?
Take 1.3mm off the bottom cap and BAM..
If even necessary..
If this was true then it would be required for ARP too, no?
safe
PostPosted: Mon Dec 16, 2019 1:32 am    Post subject: Reply with quote
You should always check the size and roundness of the big end at full torque on every rebuild. Resize if out of spec.
safe
PostPosted: Mon Dec 16, 2019 7:06 pm    Post subject: Reply with quote
As reference, the ARP and original are identical, except the stamping on the head. ARP on top.
Edit: Holy sh**, that was huge!.
See pic further down.
PostPosted: Mon Dec 16, 2019 11:44 pm    Post subject: Reply with quote
Funny, I was just having dinner last night (up here in the frozen north) with a table full of racers, including a past SCCA National Champion, and this exact topic came up; he popped a motor in his (formerly front-running) Prod car at VIR due to exactly this, didn't re-line-bore the mains on his block when he rebuilt it with new ARP main bolts, and spun a rod bearing as a result.
Now I gotta find a local shop that'll do that; the one I've been using doesn't have that tech...
TJC
PostPosted: Tue Dec 17, 2019 1:53 am    Post subject: Reply with quote
Dear safe, please delete and compress your photo and re-submit as every message after it is expanded , LOL!!!
Still on the Prowl!
www.ttrs1.com
PostPosted: Tue Dec 17, 2019 1:57 am    Post subject: Reply with quote
Well, it probably isn't worth all that just to install upgraded pistons unless your looking for more than 400 hp or so, which I'm not..
Or, might as well buy custom rods, maybe even to fit more available pistons..
Nah.. The OEM stuff will probably hold fine for long enough up to 20-25psi and be plenty fast enough..
safe's pic resized..
safe
PostPosted: Tue Dec 17, 2019 2:29 am    Post subject: Reply with quote
Thanks!
Well, for the brave you can go with this:
https://www.aliexpress.com/item/32782381728.html
Fake ARPs included!
Juho
PostPosted: Tue Dec 17, 2019 7:50 am    Post subject: Reply with quote
safe wrote:
Thanks!
Fake ARPs included!
SOMEONE MUST TRY THESE, imagine if they were actually good.
Page 5 of 7
