Posted: Sat Oct 09, 2021 9:10 pm Post subject: |
I am using a stacked plate style oil cooler like this:
https://www.summitracing.com/parts/der-13613
Mine was IIRC a B+M brand with dimensions about 8x11", so that one or similar size should work well. The stacked plate style is incredibly robust, we've stuffed it in a few tire walls and gravel traps without damage. Actually, this may be the exact one I have:
https://www.summitracing.com/parts/bmm-70266
Always, it's the cost of the fittings for all the plumbing that drives the cost up...
CV bolts; I'm not certain of the length, you'd best check, but I think they were 50mm:
https://www.summitracing.com/parts/stg-8324 _________________ Vaughan Scott
Joined: 08 Jun 2010 Posts: 1228 Location: Maysville, Colorado
Posted: Sat Oct 09, 2021 11:22 pm Post subject: |
I have the same B&M as Vaughan but will be going larger next year, pushing motor output higher and loss of efficiency due to altitude push it that way. I'll go to either Sabelt or Earl's(Holley), almost double the price.
For the CV joint bolts I bought 50mm 12.9 bolts from McMaster Carr, cheaper by the box and then use Thackery washers which are used on airplane propellers etc. they won't loosen by themselves, are inexpensive and reusable(McMaster Carr or Pegasus Racing). They torque to the washer requirements for tension rather than the bolt strength. The bolts are reusable also. I bought a set of the Grade 8 stuff, but with my old fumble fingers getting those tiny snap rings on and off would have been impossible. _________________ Mike
'67 MG Midget Dp
ChrisCXC
Joined: 18 Oct 2019 Posts: 19 Location: Los Angeles, CA
Posted: Tue Oct 19, 2021 3:14 am Post subject: |
Fantastic info guys, thanks!
OK, I'm now setting up our analog gauges and telemetry systems.
Some further questions:
1. Keeping in mind this is an endurance car (12 and 24hr races), what should we set our redline to? We have an MSD box with a limiter function. I'd rather keep it pretty conservative.
2. What should be our water temp redline?
3. What should be our optimum water temp?
4. What should be our oil temp redline?
5. What should be our optimum oil temp?
6. What is the danger zone for oil pressure?
7. What sort of numbers should I be looking for on our AFR? (we have carbs now)
8. What should be our trans temp redline?
9. What should be our optimum trans temp? |
Posted: Tue Oct 19, 2021 3:35 am Post subject: |
I'd definitely be comfortable (and we do) capping the revs at 6000rpm. It's a torque motor. Maybe even drop to 5500 if you wish.
We've seen water temps normally around 190F, but as long as you have a decent coolant cap pressure, 210F should flag a warning without really damaging.
Oil temp between 220-240F, and if you break around 270F I'd be concerned.
Oil pressure... as long as you've got more than 2 or 3 bar except at idle, no biggie. _________________ Vaughan Scott
Posted: Tue Oct 19, 2021 4:18 am Post subject: |
I have 45 DCOE Webers and the local Weber guru set them up a chassis dyno and got 13.0 and said that was perfect. I'm running 130main jets with a 190 air corrector but that is at 5000'. The Formula Ford racers tell folks coming up from low elevations to go down one size on mains so a 135 or 140 would probably be a good starting point. Air corrector typically +60 to main but not as critical. This is richer then internet"guru" recommendations. If you have Webers do not increase the venturi size, 32 for the 40's, 34 for 45's. Need to keep the air velocity as high as possible. The old Dprod guys ran 36's but then also had a better breathing head and ran at 7k+ rpm. _________________ Mike
'67 MG Midget Dp
Posted: Tue Oct 19, 2021 6:07 am Post subject: |
A standard engine normally stabilises around 120degC oil temp, but with more or less any kind of oil cooler you should get significantly lower temps even in hot weather. Revving to the max noticeably increases oil temps is my experience, shifting at 6 should be good. Normally most n/a engines produce max power at afr 12.7 or close to that
As I think I wrote before, the cars aren't so picky, at least not in standard form, if everything is in good condition it should work out just fine. _________________ 1980 924 Turbo
ChrisCXC
Posted: Thu Oct 21, 2021 8:35 pm Post subject: |
Oil pressure: no, that's not at idle. At idle it'll be below 1 bar hot. Those are on-track numbers. _________________ Vaughan Scott
Posted: Thu Oct 21, 2021 10:24 pm Post subject: |
I'll be out this weekend, I'll get an infrared temp of the tranny(not oil) for you. I doubt for our low power cars a cooler is necessary. I'd like to know myself what the tranny temp is. Use a good synthetic tranny oil, I like Redline MT-90. I'm going to change the tranny oil this winter after 3 weekends as it t probably sat with old junk oil for 15 years before I put it in the car.
I'd suggest you look at the harness bar on your roll cage, they generally recommend that the harness mounting points not be more than 4" below the shoulders to avoid compressing the spine. _________________ Mike
'67 MG Midget Dp
ChrisCXC
Posted: Fri Oct 22, 2021 10:32 am Post subject: |
924RACR wrote: | Oil pressure: no, that's not at idle. At idle it'll be below 1 bar hot. Those are on-track numbers. |
Copy that.
MikeJinCO wrote: | I'll be out this weekend, I'll get an infrared temp of the tranny(not oil) for you. I doubt for our low power cars a cooler is necessary. I'd like to know myself what the tranny temp is. Use a good synthetic tranny oil, I like Redline MT-90. I'm going to change the tranny oil this winter after 3 weekends as it t probably sat with old junk oil for 15 years before I put it in the car. |
Awesome, thanks for that!!
MikeJinCO wrote: | I'd suggest you look at the harness bar on your roll cage, they generally recommend that the harness mounting points not be more than 4" below the shoulders to avoid compressing the spine. |
It's not quite 4", but pretty close. It really depends where the seat tracks are for which driver. I'll keep an eye out for it though. |
ChrisCXC
Posted: Sat Oct 23, 2021 2:25 am Post subject: |
Oh yeah, we know. It's pretty clearly laid out in the various series we plan to race the car in.
Generally, they require 0 to 5 degrees. That we easily accomplish. |
Posted: Sat Oct 23, 2021 3:10 am Post subject: |
ChrisCXC wrote: | Oh yeah, we know. It's pretty clearly laid out in the various series we plan to race the car in.
Great, the bar seemed pretty similar to where my bar sits, and that works well. Im looking forward to your progress! _________________ 1980 924 Turbo
ChrisCXC
Posted: Thu Oct 28, 2021 3:06 am Post subject: |
OK, I'm rewiring the car from scratch.
I have a few questions:
I've been going over the wiring diagrams from the Haynes manual, but I'm struggling.
Alternator:
Where do these 2 wires go?
https://photos.app.goo.gl/VGmLD3CT2dwQ1jN87
Starter:
Where do these 3 wires go?
https://photos.app.goo.gl/XrQW59AxHhVFS6MZ6
I'm assuming one of them goes to the cutoff switch we are using:
Thanks again for all the help guys! |
ChrisCXC
Posted: Thu Nov 11, 2021 7:44 am Post subject: |
I think I've figured out the Alternator and Starter now.
Now I'm moving onto ignition.
Does anybody run an MSD 6AL with their 924?
How do you connect it to your distributor?
It seems that my distributor has 2 contacts leaving it: 1 wire within another one.
The book is a bit fuzzy as 2 what these 2 do.
Any help would be apreciated! |
