Juho
Posted: Sat Jun 27, 2020 7:33 am Post subject: |
This is how inspection went, lol |
Juho
Posted: Fri Oct 02, 2020 10:22 pm Post subject: |
Fixed the altenator mounting today so i could drive it again. I need to replace rear drums because when i took a wheel off the threads came out too.. And i still got a lot of stuff to do for inspection like making it leaner, headlights point too up, and get paperwork for coilovers. Really hard to work on the time because im in military atm. |
safe
Posted: Fri Oct 02, 2020 10:47 pm Post subject: |
I like the white wheels! |
Juho
Posted: Fri Oct 02, 2020 11:17 pm Post subject: |
i want different wheels to get better fitment on the back and also install turbo mudflaps because they make rear look so much better |
safe
Posted: Fri Oct 02, 2020 11:33 pm Post subject: |
Spacers on the rear would look nice!
Hard to find turbo mudflaps in good condition. The mounting studs are usually rusted out. |
Ratbikerich
Posted: Tue Oct 13, 2020 9:01 am Post subject: |
I ordered a manifold from Danstengineering that looks like what you are using here. Great write up and can’t wait to install my yzf600r carbs. I have a question for you: what did you use to block off your injector ports? |
Juho
Posted: Sun Oct 18, 2020 3:03 pm Post subject: |
Metal plugs and silicone ot something |
Joined: 08 Jun 2010 Posts: 958 Location: Maysville, Colorado
Posted: Mon Oct 26, 2020 3:36 am Post subject: |
The fuel injector port plugs are a 24mmx1.5 pipe plug. The are available from McMaster-Carr, metric-thread.com, possibly on ebay. At MC not cheap about $10 each, get the ones that are put in with a hex key, and external head probably won't clear the head. _________________ Mike
'77 924
cricketdesigns.com |
Ratbikerich
Posted: Thu Nov 12, 2020 8:48 am Post subject: |
Perfect. I just ordered them from MCMaster. Thanks! |
Juho
Posted: Mon Nov 30, 2020 3:37 am Post subject: |
Picked up a 931 engine today.  |
Juho
Posted: Mon Jan 11, 2021 8:12 pm Post subject: |
Bought parts to convert to 5 lug and swaybars.
Im thinking of getting new coilovers to run, have anyone used gaz golds and if i should get them with torsion delete or not. |
Joined: 08 Jan 2010 Posts: 2100 Location: Somerset, UK
Posted: Tue Jan 12, 2021 5:30 am Post subject: |
Juho wrote: | Bought parts to convert to 5 lug and swaybars.
Gaz Golds on mine for 11yrs now. Still with torsions as a 'helper' spring. Many racers/track 924+944 using them _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
safe
Posted: Tue Jan 12, 2021 5:42 am Post subject: |
Depends on your usage, but I would keep the torsion bars and use helper springs.
If you remove the torsion bars you should remove the spring plate rubber bushings. The tbars help to give some rigidity to the rubber bushings. _________________ /Magnus, Stockholm Sweden
Porsche 924 -79 NA, under EFI and turbo conversion |
Posted: Tue Jan 12, 2021 7:44 am Post subject: |
GAZ suspensions are meant to be used as helpers. If removing the torsion bars you need a holder for the spring plate. The only ones I've seen are from Lindsey or Elephant racing and quite expensive. The rear springs interfere with the bottom shock holder on the trailing arm at full wheel droop. Disconcerting when installing them, but it is not a issue when loaded. The t-bar cast housing is quite a rough casting, fitting any bushing except the stock style takes several hours of fitting. Delrin ones can take a day or two, my Powerflex black took several hours each. I used a solid bushing with angular bearing on the trailing arm as it is the piece that both rotates thru an arc and changes its angular position, the TB spring plate just rotates. _________________ Mike
'77 924
Posted: Tue Jan 12, 2021 7:27 pm Post subject: |
MikeJinCO wrote: | GAZ suspensions are meant to be used as helpers. |
Why? _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
