1 stud build
Juho
PostPosted: Fri Nov 08, 2019 7:04 am    Post subject: Reply with quote
safe wrote:
Just make one. Cardboard template, some aluminium sheet and an electric jigsaw.
I got other stuff from them so i bought the backplate aswell
Juho
PostPosted: Fri May 15, 2020 11:35 pm    Post subject: Reply with quote
Tried to fire her up today but carburetors were flooding. Any idea why? tried to loosen the fuel preassure regulator and blocking second fuel return lines, theres two in carbs and one in fuel preassure regulator
https://youtu.be/RFWaPxsQ5y0
safe
PostPosted: Fri May 15, 2020 11:45 pm    Post subject: Reply with quote
How much fuel pressure?
Juho
PostPosted: Sat May 16, 2020 1:19 am    Post subject: Reply with quote
probaly 2 psi, loosened it all the way
safe
PostPosted: Sat May 16, 2020 1:30 am    Post subject: Reply with quote
Have you adjusted the float bowl level?
Disclamer: Carbs are not my forte.
Juho
PostPosted: Sat May 16, 2020 3:49 am    Post subject: Reply with quote
not yet, didnt have time to take them off because had to leave to work
Juho
PostPosted: Mon May 18, 2020 1:24 am    Post subject: Reply with quote
ok the two tubes on the top arent returns... they are just breathers
safe
PostPosted: Mon May 18, 2020 1:44 am    Post subject: Reply with quote
Carbs Usually doesnt have returns. The floats just closes the "fill valve" needle valve. So to set the floats levels is crusial.
PostPosted: Mon May 18, 2020 2:55 am    Post subject: Reply with quote
Safe's right. On my Webers I run a fuel pressure regulator at 2psi(max for Webers is maybe 3.5. with no return. In US Holley 804 is an inexpensive fuel pressure regulator. I also use a Carter P4070 fuel pump something like 4-8 psi output.. Many of the racers use Facet pumps, but not the really cheap cube one. Different carbs will want different fuel pressures. Some pressure regulators will have a bypass/return in them.
On the race car I have an in line pre filter (85-100m) Then run thru the pump to a stock 924 Bosch filter(interesting finding fittings) then the pressure regulator. The street car just has a really cheap($3) plastic filter from any flaps.
Mike
'77 924
cricketdesigns.com
Juho
PostPosted: Mon May 18, 2020 4:50 am    Post subject: Reply with quote
gonna take them off tomorrow and clean the needles and if that doesent fix it ill try to set the float level no idea how to do it though
Juho
PostPosted: Thu May 21, 2020 4:02 am    Post subject: Reply with quote
https://www.youtube.com/watch?v=Pt-77UrGv0M
should they be like this when i flip them upside down and back they sometimes they get stuck. they go back by pushing or hitting bowl with screw driver.
Juho
PostPosted: Sat May 23, 2020 6:06 am    Post subject: Reply with quote
Cleaned carbs today and the they still flood
safe
PostPosted: Sat May 23, 2020 6:24 am    Post subject: Reply with quote
What kind of carb is it!?
The 40ish degree you have mounted the carbs at, is that within the allowed spec?
As Ive said, Im no carb Guru, but i think you must mount them pretty much horisontal.
Juho
PostPosted: Sat May 23, 2020 7:45 am    Post subject: Reply with quote
ive seen plenty mounted at an angle like this. i think i need to adjust level but no idea how to do it.
Juho
PostPosted: Sun May 24, 2020 6:03 am    Post subject: Reply with quote
Another day of testing, mounted the carburetors more horizontally. Tried to bending the tangs that adjust the float level from all they way up to all way down. Any of those didn't help and the carburetors are still flooding.
Page 3 of 5
