1 stud build
Juho
PostPosted: Tue Oct 22, 2019 5:32 am    Post subject: Reply with quote
While soldering lambda wires melted a little bit of the bucket seat fabric and now im pssed
Juho
PostPosted: Wed Oct 23, 2019 2:31 am    Post subject: Reply with quote
Quick question, are these wires the correct way?
Juho
PostPosted: Wed Oct 23, 2019 5:06 am    Post subject: Reply with quote
ive just realised i installed bearing caps wrong way..... i guess its time to do it again tomorrow
Juho
PostPosted: Wed Oct 23, 2019 5:25 am    Post subject: Reply with quote
2,3,4 are wrong way right? I read the manual and thought the 459 was supposed to be readible from back of the head
Juho
PostPosted: Wed Oct 23, 2019 6:11 am    Post subject: Reply with quote
The 459 is readible from back of the head but the stamps arent.
safe
PostPosted: Wed Oct 23, 2019 6:26 am    Post subject: Reply with quote
Aren't they asymmetric?
Juho
PostPosted: Wed Oct 23, 2019 6:33 am    Post subject: Reply with quote
Yes, 3 rounded corners and 1 sharp, mine are facing right direction when i look at other peoples caps from other posts, but haynes manual says that the stamp should be readible from back of the head
safe
PostPosted: Wed Oct 23, 2019 6:47 am    Post subject: Reply with quote
Yes, but isn't the distance between the studs and cam different side to side so you cant put them on backwards?
Juho
PostPosted: Wed Oct 23, 2019 7:19 am    Post subject: Reply with quote
I dont know, shouldnt be mine be good when compared to these pictures
PostPosted: Wed Oct 23, 2019 8:54 am    Post subject: Reply with quote
Does the cam turn? Having the caps on the wrong way will bind it up. Valve spring tension on the lobes is the only thing that prevents it from easily turning when the caps are on correctly. There ought to be a few places where you can rotate the cam back and forth a bit.
1979 924 NA race car
1982 924 Turbo almost a PoS
Juho
PostPosted: Fri Oct 25, 2019 4:53 am    Post subject: Reply with quote
I've created a whole new vocabulary in my garage past these weeks....
Ive only got to put on the timing belt and get a bigger fuel line for the regulator to carbs because the expensive one i got atm doesent fit. Then i should be able to start it. and also tighten camshaft cover and intake manifold bolts <------ anyone have tips for doing them?? its so annoying
Juho
PostPosted: Fri Oct 25, 2019 4:54 am    Post subject: Reply with quote
oh yeah, guess whose hood isn't going to close
safe
PostPosted: Sun Nov 03, 2019 2:40 am    Post subject: Reply with quote
How is it going?
Started up yet?
Juho
PostPosted: Thu Nov 07, 2019 10:15 pm    Post subject: Reply with quote
so the backplate i ordered doesent fit sending it back and waiting for a new one
safe
PostPosted: Thu Nov 07, 2019 10:51 pm    Post subject: Reply with quote
Just make one. Cardboard template, some aluminium sheet and an electric jigsaw.
Page 2 of 3
