1 stud build
Goto page 1, 2, 3, 4, 5, 6  Next
Juho
PostPosted: Sun Sep 29, 2019 1:30 am    Post subject: 1 stud build Reply with quote
Started a new thread for my build because ive got no clue what im doing with it atm. Got itbs, bike carbs, supercharger laying around atm.
When i was taking intake manifold studs (which are in cylinder head) off i broke 1 of the studs so now i have to get the head off, get it machined and replace the hg and put this all s*** together. Thats why im calling it 1 stud build because all of this is because of it.
This is my first time ever taking a really anything bigger off than waterpump from my 924 because its been very "reliable" track car.
Tried taking off the exhaust before pulling the head but my knuckles already said no to that. And lost my 13mm somewhere in narnia (rolled down the engine mount).
Ive already taken some coolant lines off, everything related to intake and distributor. Which timing i think i f**** it because the engine isnt tdc atm and i took it off and spun gears. I havent taken the timing belt off because the engine isnt tdc atm.
Ill be posting pictures of this later today, need to tidy up the garage more to pull the head off (need table space). Also i hope ill be finding my haynes manual there.
Juho
PostPosted: Mon Sep 30, 2019 12:35 am    Post subject: Reply with quote
Fun times
Juho
PostPosted: Tue Oct 01, 2019 5:05 pm    Post subject: Reply with quote
manifold removed from rest of the exhaust. Just got one annoying 7mm nut behind the head and its ready to come off.... hopefully today
Juho
PostPosted: Wed Oct 02, 2019 5:44 am    Post subject: Reply with quote
Well just did a 45 minute trip for wrong size bolt, anyone knows the size of the xzn head bolt?
safe
PostPosted: Wed Oct 02, 2019 5:50 pm    Post subject: Reply with quote
I just try one socket after the other until one fit... Buy a set.
Juho
PostPosted: Thu Oct 03, 2019 6:45 am    Post subject: Reply with quote
This was scary but yeh. Job done but not well
safe
PostPosted: Thu Oct 03, 2019 7:19 pm    Post subject: Reply with quote
Step no1 done!
Keep track of TDC on the crank, cam and distributor and it vill go together smoother if you are unsure.
Juho
PostPosted: Wed Oct 09, 2019 4:47 am    Post subject: Reply with quote
Picked up the head from the shop today . Should i do something to the surface rust on water jackets?
safe
PostPosted: Wed Oct 09, 2019 5:03 am    Post subject: Reply with quote
Na, but assume the shop stuffed as much metal chips as possible down every orifice as clean accordingly....
Juho
PostPosted: Wed Oct 09, 2019 5:46 am    Post subject: Reply with quote
Im going to buy a compressor tomorrow to clean everything before i put them back together.
PostPosted: Wed Oct 09, 2019 7:22 pm    Post subject: Reply with quote
Surely the machine shop would deep clean/put in a parts washer after working on the head before rebuilding??????
safe
PostPosted: Wed Oct 09, 2019 7:57 pm    Post subject: Reply with quote
Doesn't look like the head has been dissembled or cleaned, based on the crud still on the head and carbon on most valves.
You can fly cut it without removing the valves.
Juho
PostPosted: Thu Oct 10, 2019 4:08 am    Post subject: Reply with quote
I only took off the camshaft, just got the broken studs drilled out and head decked
TJC
PostPosted: Fri Oct 11, 2019 1:59 am    Post subject: Reply with quote
Just out of curiosity why didn't the machine shop freshen up the head while you had it in there? Have you have a valve job, guide check, seals, etc. done very recently?
'95 BMW 318i/5 ..."Pearl"
Still on the Prowl!
www.ttrs1.com
Juho
PostPosted: Fri Oct 11, 2019 4:38 am    Post subject: Reply with quote
I didn't have them done, but i think last owner did because he put the aftermarket camshaft in and replaced all the gaskets because they all seemed pretty fresh. I didn't get anything else done to the head because I am disassembling whole engine after next summer's track days and i might be getting turbo cylinder head and forged internals.
Page 1 of 6
