Engine out: What else?
Raize
PostPosted: Mon Sep 23, 2019 4:34 am    Post subject: Engine out: What else? Reply with quote
I've taken the engine out of my 924 for some maintenance (mainly leaky gaskets) so it's in good shape for boost from the Eaton M62 supercharger which I now attached to it.
Any recommendations for things I should do or check while it's out?
PostPosted: Mon Sep 23, 2019 6:15 am    Post subject: Reply with quote
Main seals front and rear, belly pan seals.
Would you share with me the mounting solution for the supercharger?
Iím trying to design the mounting for the charger in such a way that no additional mods are reuired. Not sure its possible tho..
PostPosted: Mon Sep 23, 2019 10:50 pm    Post subject: Reply with quote
Any reason not to do a full refresh, rings bearings and the like?
'79 924 #77 ITB racecar
PostPosted: Tue Sep 24, 2019 12:15 am    Post subject: Reply with quote
Cleaning, painting and general tidying up of the engine bay? Don't know if its "needed" for your car, but I have only seen one or two where it hasen't.
Ozzie
PostPosted: Tue Sep 24, 2019 8:16 am    Post subject: Reply with quote
core plugs?
Its AUTO and its BLACK
Montego Black on black/red
