austinporsche
Posted: Tue May 21, 2019 3:17 pm Post subject: AC system electrical operation -- is this right? |
Hi all.
FYI, I have a separate post on the general discussion board about where the AC relay is if you want to help out on that as well.
This thread is about better understanding the electrical workings of the 924S' AC electricals.
Based on the schematic on the side of the alleged AC relay as sold by Pelican (see link), it looks like it is a relay with dual contacts, i.e., one input signal throws two output contacts.
https://www.pelicanparts.com/catalog/SuperCat/0992/POR_0992_ELSWCH_pg2.htm#item7
This would seem to be consistent with how the AC in my 924S works as the big black-and-white AC dial in the middle of the dash both operates the blower motor AND presumably the compressor as well.
Do i have this about right?
If so, would it be possible that the contact for the compressor is stuck while the contact for the blower motor is not?
That's my situation: the blower motor runs when the AC knob is turned, but not the compressor.
And if I have this right, does anyone know which output pin is the compressor clutch and which is the blower motor? (87 and A are presumably the output pins to those two loads, but no idea without a full wiring diagram, which one is which).
Pins 85 and 86 are presumably in the AC-Blower switch circuit |
16again2009
Posted: Wed May 22, 2019 2:42 am Post subject: |
I went through this exact thing about a year ago. Did everything to the ac and the compressor would not kick in. I replaced the ac relay and that didn't help. Behind the glove box, just to the right of the ac relay is a little black retanglular box. I can't remember what it is called. I took it apart and it had a burned circuit. I put a drop of solder over the burned spot, re-installed it and have had cold ac ever since. Good luck. _________________ 1988 porsche 924s
5 speed |
austinporsche
Posted: Wed May 22, 2019 10:26 pm Post subject: |
Thanks. So before the fix, the fan blew but the compressor clutch wouldn't engage, right?
Couple of questions:
1. The 5 blade tall AC relay (the link in my original post) is behind the glovebox? No documentation I have looked at shows it as being there: how did you figure that out?
2. Any idea what the little black box is? maybe an early version of what is now commonly called a BCU -- body control unit? Guessing you don't have pics.
3. Do you have to remove the glovebox to get to the relay and black box or can you get to them from the underside? |
16again2009
Posted: Thu May 23, 2019 11:54 am Post subject: |
Yes, that is the same symptoms I had. You have to remove the panel below the glove box and the glove box. About a 20 minute job. It is to the right of the a/c relay. It is a small black square. The electric to your compressor goes through it. The part number is 477959531. I have seen it referred to as a blower motor fan resistor, an a/c adjusting relay, and an a/c amplifier. Take your pick. It is all the same part. I took mine apart, soldered the burned circuit and the compressor started working. I have pictures but this forum does not have a mechanism to post them direct. You have to post them through a photo program which I do not have. But if you will google the part number there are pictures of it online. The whole job took me about 1 1/2 hours. Good luck. _________________ 1988 porsche 924s
5 speed |
16again2009
Posted: Thu May 23, 2019 11:55 am Post subject: |
Also posting the year of your car would help. _________________ 1988 porsche 924s
5 speed |
austinporsche
Posted: Fri May 24, 2019 7:43 am Post subject: |
1988 . . . |
austinporsche
16again2009
Posted: Fri May 24, 2019 1:19 pm Post subject: |
Yes, that is the part. The early 944 uses the same part. It is a blower switch but the wiring for the magnetic clutch on the compressor goes through it. So replace it with one of your spares or fix the one that's in there. If that is your problem it will work. If it doesn't it's something else. Only one way to find out and it is a free fix. Good luck. Let us know how it turns out. _________________ 1988 porsche 924s
5 speed |
austinporsche
Posted: Sat May 25, 2019 5:56 am Post subject: |
Will do. Going to try to get to it this weekend . . . . |
austinporsche
Posted: Mon Jun 03, 2019 1:14 am Post subject: |
ok, so I got up to where i store my 924 yesterday.
one new piece of data.
when l turn on the AC via the blower switch, the fans kick on, but not the compressor clutch.
does this mean the blower relay in the fuse block is good, but the other relay under the glovebox is bad? |
Joined: 28 Feb 2008 Posts: 1138 Location: Washington DC area
Posted: Mon Jun 03, 2019 2:29 am Post subject: |
There must be refrigerant under some pressure in the system for the clutch to engage. If it has all leaked out, you will never get the clutch to engage regardless of the rest of the wiring and controls being perfect. If your system is 134A, you can go to an auto parts shop and buy a can that comes with a gauge attached to the injection port. The gauge is reusable on further cans of 134A.
You don't have to have the engine running to test. Just attach the can with gauge to the low side of the compressor (fittings are different size so you can't get it wrong) and see what the gauge says. If its over 15 - 30 pounds the clutch should work. If it's zero, squirt the entire can into the system, start the car and see if the compressor clutch kicks in. If so, put another can on the gauge, reattached to the compressor and follow the directions for a rough equivalent of 'full".
If you had internal pressure all along or after adding a can or so of refrigerant, and it still won't activate the clutch, you have a wiring problem. _________________ 1979 924 NA race car
1982 924 Turbo almost a PoS
austinporsche
Posted: Mon Jun 03, 2019 4:36 am Post subject: |
Pressure read 50psi, so all good there.
I am taking out this second resistor/relay from behind the glovebox today to see what is going on with it.
So here's what I know:
AC system properly pressurized (though pressure switch could be bad?)
When AC switch (AC fan speed switch) turned on, cabin fan run
When AC switch (AC fan speed switch) turned on, condenser fans run (both?)
When AC switch (AC fan speed switch) turned on, compressor clutch doesn't energize (engage) |
austinporsche
Posted: Mon Jun 03, 2019 10:48 pm Post subject: |
Can't figure out how to insert an image. A little help.
If there was an image attached, 16again2009, is this the board and the "brown spot" to which you are referring.
Definitely solder is missing, didn't migrate anywhere else and wasn't in the cap of the electronic component, so did it just vaporize?
A dollop of solder on that -- not not touching the adjacent solder point(s) on the board -- should do it then?
[/img] |
austinporsche
Posted: Thu Jun 27, 2019 4:53 am Post subject: |
I started working on the AC this past week, and first, I was wrong about the pressure.
As long as a can (Redtek R12a) was on a filling, the pressure was 30-40psi, but once can was closed, pressure dropped and I could hear a "hiss" along the firewall.
It's a routing nightmare back there on the firewall, so if anyone has an exploded view of the AC system, that would be most appreciated.
Otherwise going to start a new thread to see if I can get some answers (it'll be the same thread I just posted on Pelican). |
