WTB: 931 torque tube and shift linkage
1QuickS
PostPosted: Sat May 18, 2019 10:26 am    Post subject: WTB: 931 torque tube and shift linkage Reply with quote
I am in Salem, Oregon. I'm interested in acquiring 924 Turbo torque tube and shift linkage.
Contact me via email address:
info@PerformanceOriented.com
Thanks, Paul
Paul Abbott
www.PerformanceOriented.com
Kenodog
PostPosted: Wed May 22, 2019 11:25 pm    Post subject: Reply with quote
Hi Paul, welcome to the Board.
Is this for an S1 or S2 car ?
Lee
1979 Euro 931, Olive
1981 931, Sabine
2014 Mazda CX-5 (Kinderwagon)
2008 GS500
1996 Dodge Caravan (DJV)
1QuickS
PostPosted: Thu May 23, 2019 12:56 am    Post subject: Reply with quote
Hi Lee,
Well, it is for a 88 944S that I have a snailshell for.
Paul Abbott
Kenodog
PostPosted: Thu May 23, 2019 5:34 am    Post subject: Reply with quote
You do realize that the block is not the same for the front and neither is the torsion bar carrier right ? The snailshell mounts to two arms protruding rearward from torsion bar carrier itself. Only the S1 924 turbos have these arms....
Me
1981 931, Sabine
2008 GS500
1QuickS
PostPosted: Thu May 23, 2019 5:46 am    Post subject: Reply with quote
Yes, I was planning on fabricating & welding gearbox mounts to torsion tube once everything was in place.
Can you elaborate on what you mean by "block"?
Paul Abbott
PostPosted: Thu May 23, 2019 7:36 am    Post subject: Reply with quote
Well i used a 944S2 drive train on a 931 engine and it worked, should work the other way around as well, meaning 931 TT and gearbox on a 944 bellhousing and clutch.
Still, no idea why you’d want a snailshell on an S...the Audi boxes are much more refined and modern feeling, just like the S is compared to the 931.
The snailshell makes sense in an iron brute machine like the 931 but not in a modern car like the 924S.
red 924 and not red 924
1QuickS
PostPosted: Thu May 23, 2019 8:14 am    Post subject: Reply with quote
I like dogleg boxes, had three SWB 911s (one for 38 years) and a 911 SC. I prefer the shift pattern. Also, the snailshell is Porsche design and is a lighter, more compact design with gearbox ahead of rear axle. The Audi box is a "parts bin" selection, designed for front wheel drive car and places gearbox behind the axle in the 944.
My 944S is mostly unrefined now with the only remaining power accessory being the sunroof. Power steering, air conditioner, power brakes, cruise control, power windows, power door locks, center console, impact-resistant bumpers, pop-up headlights, power mirrors, power seats and rear seats are gone and more to go away. Also, I am nearly finished with designing a carburetor setup to replace Motronic. Clearly, I like unrefined.
Paul Abbott
PostPosted: Thu May 23, 2019 8:44 am    Post subject: Reply with quote
I agree on the dogleg. I raced an early 911 with dogleg and a later one without. I also raced a 82 924 with Audi box and now a '79 dogleg 924. MUCH prefer the dogleg pattern on the track.
1979 924 NA race car
1982 924 Turbo almost a PoS
PostPosted: Thu May 23, 2019 5:07 pm    Post subject: Reply with quote
In that case, yes it makes all the sense to use the snailshell.
I know the audi box is crap, my higher boosted 931 mashed a 944 box under load going up on a bridge.
Good luck finding the parts.
1QuickS
PostPosted: Fri May 24, 2019 1:15 am    Post subject: Reply with quote
Thanks for the encouragement on finding a driveshaft!
Cheers, Paul
Paul Abbott
1QuickS
PostPosted: Sun May 26, 2019 12:44 am    Post subject: Reply with quote
Well, thanks to all who looked/responded to this request. I have found a solution to my problem and no longer seek a 931 torque tube.
Paul Abbott
Britain
PostPosted: Wed Jun 05, 2019 4:08 pm    Post subject: Reply with quote
I am curious to what you came up with.
If you need to unload that G31, I would be interested. I am in Hillsboro.
-Britain
1QuickS
PostPosted: Wed Jun 05, 2019 4:26 pm    Post subject: Reply with quote
Well, the plan is unique and I expect funny responses.
The plan is to use a 944 torque tube assembly and shorten the driveshaft and torque tube to interface with the 931. Use a 931 coupler and bore the forward end to receive the 944 driveshaft and silver solder the coupler to the shaft.
Paul Abbott
PostPosted: Wed Jun 05, 2019 4:40 pm    Post subject: Reply with quote
Bodge, dont do it. Will vibrate and destroy the input bearing and seal of the gearbox and maybe the bearings in the torque tube.
Just get a 931 torque tube, there are plenty of 931 being parted in the US.
Post new topic   Reply to topic    924Board.org Forum Index -> Cars and Parts Wanted/For Sale All times are GMT + 10 Hours
