Heater & AC control and cables
ted von Kampen
PostPosted: Tue May 14, 2019 10:06 am    Post subject: Heater & AC control and cables Reply with quote
I have a 1981 Porsche 924 NA that I have been restoring. I recently found the heater control panel and attached Bowden cable are not working correctly. While I found that the lower plastic edge has broken in one corner, I have a question that maybe someone can answer. On the middle lever there appears to be 2 Bowden cable attached. One goes to the hot water cooling valve in the engine compartment. Where does the other one go? Also on the middle lever there appears to be 3 holes where the cable attaches. To which holes do the 2 Bowden cables attach? and which cable goes to which hole?
The upper lever goes to a flapper door as does the lower lever. I hope someone can answer these questions. Thanks in Advance.
Ted von Kampen
