tofuricer
Posted: Wed May 01, 2019 10:06 am Post subject: Brake Pedal Height Adjustment |
My '87 924S has been having a brake dragging issue. The pedal is really high and engages immediately when I press on it. I can hear and feel the brakes dragging, mostly the rear. The e-brake is not engaged.
I am thinking that the P.O. adjusted the pedal so high that the calipers can't fully release.
However, I am looking at this yolk and nut and not sure how it works. Do I pull the pin and then rotate the whole yolk? The only way to get enough room to do that would be to bleed the brakes, but before I do that, I want to make sure I am
1) doing this right?
2) not missing something else I should be checking first?
Thanks! _________________ 1987 924S |
Joined: 02 Nov 2002 Posts: 9461 Location: Southeast Wisconsin
Posted: Thu May 02, 2019 2:09 am Post subject: |
I'm guessing the calipers' sliders need cleaning. _________________ White 87 924S "Ghost"
Posted: Thu May 02, 2019 3:08 am Post subject: |
The actuating rod is a hex piece. Loosen locknut, rotate rod. _________________ Toofah King Bad
- WeiBe (1987 924S) - 931 S3
